P0021?
Old Mar 12, 2012 | 12:06 PM
Nismo_max04's Avatar
P0021?
P0021 - Intake (A) Camshaft Position Timing Over Advanced..Bank 2...any info for the 04 SE's with this problem? Cause/effects?
Old Mar 12, 2012 | 03:43 PM
naijaboy's Avatar
Low oil or timing chain
Old Mar 12, 2012 | 08:09 PM
Just had timing chains & guides replaced by the dealership last week..primary & secondary ones. How could that not have diagnosed this problem b4 they gave the car back to me?
Old Mar 13, 2012 | 03:05 PM
L36's Avatar
L36
Bank 2 is over advanced, had same issue when i did timing chain. They need to go back and redo it.
Old Mar 13, 2012 | 06:29 PM
What exactly needs to be re done? I went back to the dealership today and they told me I just needed to replace the sensor and get an oil changed....all they did was hook up the CPU and run the monitors to check if the cams were lined up correctly, which they were...I guess since I already have the sensor I'm gonna put it in but if something is still giving me issues I'm going right back and demanding they re-do the job.
Old Mar 13, 2012 | 06:58 PM
L36's Avatar
L36
If they hooked up consult and said the cams are fine, then its either the camshaft sensor or the VTC solenoid.
Old Mar 13, 2012 | 07:35 PM
Ok..is there a DIY write up on how to replace the bank 2 sensor? I know it's on the cylinder head closest to the radiator..I did the bank 1 b4 with no issues so this shouldn't be any harder
Old Mar 13, 2012 | 07:56 PM
L36's Avatar
L36
Its quite simple, just remove one 10mm bolt holding the sensor, unhook the harness and pull it out.
Rinse and repeat. To test the VTC solenoid, measure the resistance between the two terminals of the VTC solenoid. You should be getting 7-7.5 ohms on a cold engine with ambient temp @ 20C If you get abnormal readings more by .5 ohms, you got a problem.
Old Mar 14, 2012 | 01:27 PM
naijaboy's Avatar
Changing the solenoid or sensor wont fix it.
They'll eventually need to re-do the job if an oil change doesnt get rid of the code.
Old Mar 14, 2012 | 08:53 PM
What did they do wrong during the install to cause that?
Old Mar 15, 2012 | 08:32 AM
Update: I'm getting a grinding noise coming from the timing chain area. Very unusual sound. you can hear in the the cabin if all components are off. Calling the dealership and telling them to re do it
Old Mar 15, 2012 | 01:45 PM
L36's Avatar
L36
Might be the idler pulley.
Old Aug 8, 2012 | 09:27 AM
bazzaretta's Avatar
I have the same problem on my SL 04. I changed the Camshaft Position Sensor, but the symptoms are the same (not as frequent, though). Do you mind telling me how much you paid for the timing chains & guides replacement? Thanks!
Spectre77
Feb 2, 2017 06:15 PM
mclasser
Jul 12, 2015 08:47 AM
xzile609
Jun 11, 2012 02:19 PM
02SE6MT
19
May 8, 2012 05:53 PM
Colossus
Jul 10, 2010 03:10 PM
