Dont know sh$@ about Nissan and need a little help
Old May 8, 2012 | 06:55 PM
Euro8's Avatar
So here is the problem today on my G/F's way home her 06 Maxima 3.5 SE stalled out on her the car pretty much locked up on her. As she was stopped to pull into our parking structure her steering locked up (she may not be able to handle no power steering though), the brakes could not be pushed down, the ABS, TCS, SLIP and check engine light all came on. When this happen she immediately put the car in park or neutral (she has no idea) and turned it off. In order to get the car into neutral in order to move it she had to use her gear unlock, don't know if that's the right terminology for it. One of the mechanics that lives at the complex looked at it and messed around with the throttle sensor and it started back up. When I got home I went and looked at it and drove it, it drove fine. I looked at all the connections to the MAF and throttle body and everything seemed to look good.
Could anybody help me troubleshoot this so I don't need to hit up the dealership!!
Old May 8, 2012 | 07:09 PM
NismoMax80's Avatar
SuPeRmOd
Sounds like she lost power or went into safe mode. Is there a CEL? just have the code read.
But there is no 2.5 Maxima.
Old May 8, 2012 | 07:23 PM
Euro8's Avatar
Thats what i have been reading is that it went into safe mode but have not found anyone with the similar issue and to what could cause that to occur. The only CEL that pops is the service engine soon light, which was not on prior to the incident.
Old May 8, 2012 | 07:25 PM
Euro8's Avatar
Sorry meant to say 3.5
Old May 8, 2012 | 07:26 PM
NismoMax80's Avatar
SuPeRmOd
that's exactly what I mean. Take it to Auto Zone and they will read that code for free. Then we can help you or a garage will know what to check.
Old May 8, 2012 | 07:31 PM
Euro8's Avatar
Sounds good, Thanka for the help
Old May 8, 2012 | 07:35 PM
Euro8's Avatar
Just called autozone to head over to get the codes read and the lovely state of CA banned autozone from allowing that service, due to the fact that they are not a repair shop. I hate this damned state!!
Old May 8, 2012 | 07:39 PM
NismoMax80's Avatar
SuPeRmOd
crap so sorry to hear that. well if you don't have a decent mechanic to check it for cheaper, you still need one to fix it so pay them. or buy a scanner and do it yourself.
Old May 8, 2012 | 08:33 PM
Euro8's Avatar
Went out and bought one, the code it is throwing is a P0340 crank shaft position sensor A - Bank 1 circuit malfunction.
Old May 8, 2012 | 10:12 PM
Euro8's Avatar
Is this a common problem with these cars? Also is there any other sensors that should be changed along with the camshaft sensor ?
Old May 9, 2012 | 01:57 AM
NIKV69's Avatar
Very common. No just do the cam sensor. I had this happen to me and I did both just to be safe. Clear the codes and you're done.
Old May 9, 2012 | 08:19 PM
Chris Alexander's Avatar
So guys if the cam shaft sensor/Crank Shaft goes out the car will stall? what are the warning signs of a bad one? hard starting? and is it covered under warranty?
Old May 9, 2012 | 10:30 PM
NIKV69's Avatar
May or may not stall. Mine just went into safe mode. Able to drive it but will seem like tranny is blown. No warning signs really. Just light on and in safe mode. Usually will happen way past warranty.
Old May 9, 2012 | 11:07 PM
I bought my 06SL last January and did almost 4000 dollars worth of repairs, Timing chain 2700, motor mount 800,steering wheel shimming 200 (road force balance,and its just now riding like a brand new trouble free car I hope I dont have Camera sensor/Crankshift problems.
Mar 12, 2020 12:06 AM
Bernhard
Sep 14, 2015 12:49 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
coasterswim
Sep 2, 2015 07:43 AM
