Throttle lag.
Old Jun 9, 2012 | 06:33 PM
L36's Avatar
L36
Throttle lag.
Hello.
Having this weird issue, when im driving at constant throttle, i sometimes feel a dip like car slightly dies down and then gets back to normal cruising. Its like a split second dip, or lag so to say. Began happening recently, no codes, M/T.
Has anyone encountered such problem on a 6th gen?
Thanks.
Old Jun 10, 2012 | 09:34 AM
Longhorn101's Avatar
Mine did the same thing several times randomly just days before my Camshaft Position Sensor went out causing the car to completely shut-off. You might check to see if there are any pending codes that just haven't tripped the light yet.
good luck.
Old Jun 11, 2012 | 03:32 PM
twentyeggs's Avatar
they only thing i've had similar is in 3rd gear (i think) when i am accelerating at 3/4 throttle right at about 4.5k rpm the revs will pause for 1-2 seconds in the range, however my speed continues to increase irregardless of the pause. quite weird, but it hasn't bugged me enough to get it checked out. I am pretty sure a tune would smooth that out but again it doesn't really effect my driving and im not racing ATM so it doesn't matter if it slows me down a 2/10ths of a second.
Old Jun 11, 2012 | 08:34 PM
T_Behr904's Avatar
Sounds like E-throttle "lag".
Old Jun 12, 2012 | 09:30 AM
L36's Avatar
L36
To me it feels like the a/c compressor is engaging when its not supposed to. Regardless of a/c being on or off, this lag happens. Not sure if a/c relay has anything to do with this.
Old Jun 13, 2012 | 04:37 PM
KCMAXX's Avatar
KC's FINEST
Try cleaning the throttle body. It makes a big difference.
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 16, 2015 12:17 PM
Bonka
Sep 14, 2015 11:18 PM
