04 maxima headlight condensation
Old Jun 22, 2012 | 02:56 PM
flores703's Avatar
so i install my hid last night and today was like 90+ here in virginia and i forgot last night to put glue on the rubber piece that comes with the hid and im stating to get condensation inside of my headlight.. what can i do now to stop it or anything?
Old Jun 22, 2012 | 08:00 PM
KCMAXX's Avatar
KC's FINEST
Wow...
Old Jun 26, 2012 | 07:53 AM
flores703's Avatar
yeaaaaaaaaaa help
flores703's Avatar
i was thinking of blowing air into it
Old Jun 26, 2012 | 08:16 AM
twentyeggs's Avatar
no.........
Step 1: Google Silica gell, click shopping tab, select a good price (5-10 bucks)
Step 2: open box, get fishing line/thin string, tie (tightly) to the packets
Step3: slip the packets inside the housing
Step 4: tape the opening closed and leave car overnight
Step 5: remove tape, remove packets, condensation is fixed.
Step 6: no more comments and/or faces from KCMAXX
Old Jun 26, 2012 | 08:20 AM
twentyeggs's Avatar
or
Step 1: go get hair dryer
Step 2: use hair dryer
Step 3: condensation fixed
Setp 4: no more comments and/or faces from KCMAXX
Old Jun 26, 2012 | 08:24 AM
flores703's Avatar
Originally Posted by twentyeggs
or
blow hot air from the dryer into it or from the outside?
Old Jun 26, 2012 | 08:47 AM
twentyeggs's Avatar
i'd start with the outside, that way the surface of the plastic will get hot and the evaporation process will start via conduction. Once the visible water spots have dissipated blow air into the housing to flush out the high humidity you just created.
be careful tho, hair dryers are very hot so every so often make sure the plastic is not getting too hot. If you cant hold your hand on the plastic for 3 seconds its too hot
Old Jun 26, 2012 | 08:52 AM
twentyeggs's Avatar
I would still buy a 3 dollar silica packet to place in the housing as this will eliminate any left over moisture by 100%.
i have NO idea if this would work at all but get a zip lock and place a cup of uncooked rice in it, take a needle and poke a LOT of small holes in it, Place the bag and rice in the housing overnight. I know rice wicks up moisture but its not nearly as fast and effective as silica gel. Just a thought, it may be a home run, or you may rip the bag as you pull it out and get rice all over the place.
Or you could just throw rice at all the hondas out there...
Honda's demand rice, so give them rice, just dump a bunch of rice behind their 5" outlet cannons/mufflers.
Old Jun 29, 2012 | 08:01 PM
6.5affiliate's Avatar
You don't need to glue the rubber grommet. Think your problem is that you might have made the hole a bit too big (where you insert the HID into the housing). That will allow moisture into the headlight leading to condensation.
Since it's so hot over there. Just remove the harness and bulbs and let it sit in the sun for a few hours. When your finished. Put everything back together and use some clear silica and put it around the rubber grommet.
Just in case. Do that part inside and let it sit for a few days for the silica to cure before re-installing it on your ride.
Should be good for awhile after that.
Old Jul 1, 2012 | 02:20 PM
mrjasonlyrics's Avatar
If you didn't have condensation issues before and you didn't open your headlight then you don't have anything to worry about. On the other hand if you had a non HID and you drilled holes to run the HID bulbs then that's where you should focus on. If you have space as the members said you should use selicone to seal it from moisture getting in. Good luck
Dennis Twohy
Oct 1, 2015 06:01 PM
wingsfan24
Aug 15, 2015 07:35 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
dauntlessmax
Aug 5, 2015 10:29 AM
