Tired of trying!!!
Old Jun 23, 2012 | 08:03 PM
khg186's Avatar
Tired of trying!!!
I have a 2005 Maxima SE, i recently installed HID'S on the headlights and fogs, and replaced the bulbs on the cornering light with white LED's. I installed everyrhing fine and everything worked but know my right headlight and my corning lights dont work ( but the RH fog works). Every light works except my RH headlight and my cornering light. Tested all the bulbs and the r good. The funny part is that when i attach a reg bulb ( non-hid) on the rh headlight it works. So tried mutiple things and had no luck. So canu guys pls help me
Old Jun 23, 2012 | 08:16 PM
NismoMax80's Avatar
SuPeRmOd
pretty sure others have tried LED corner lights and they just won't work.
You installed the ballasts for your HID right?
Old Jun 23, 2012 | 08:30 PM
khg186's Avatar
Yeah but i installed them like three weeks ago and they were working fine, an the cornering were working too
Old Jun 23, 2012 | 08:47 PM
khg186's Avatar
Whats that dilema with led cornering lights?
Old Jun 23, 2012 | 08:49 PM
mrjasonlyrics's Avatar
The problem is in your connector man. I'm pretty sure. Make sure the socket it in properly. I had the same issue a few weeks back. Just wiggle the connector and push it in all the way. If you're sure it's not that try using a tester and see if you're getting power. Good luck
Old Jun 23, 2012 | 08:56 PM
khg186's Avatar
So what so u think about my rh headlight, the reg bulb works but not the hid bulb, mind u it was working for like about three weeks and i tested yhe bulb and the ballast and they r good. Can it be a fuse or something?
Old Jun 23, 2012 | 10:24 PM
Check the fuses and it they are good then try my method. You just have to trouble shoot.
Old Jun 24, 2012 | 11:48 AM
khg186's Avatar
i blew a couple of fuses and finally fixed the headlight but now my left headlight doesnt take the high beams on low, but the
Old Jun 24, 2012 | 11:50 AM
khg186's Avatar
i blew a couple of fuses and finally fixed the headlight but now my left headlight doesnt take the high beams on low, but the rh does. i also got the led cornering lights to work but only the LH, getting some progress
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
