6th Gen Alternator Replacement thread?
Old Jul 10, 2012 | 09:35 AM
pktaske's Avatar
Searched and searched but could not find anything of note. Seems like these are a bear and I want to do my research before I start. Any step-by-step, video or basic walk-through would be appreciated. I think I'm going to invest in a decent one as I've read alot about bad non-OEM alternators. Maybe I'm just gun shy from reading so much.
Also seems like "The Garage" forum is pretty desolate...eh?
Old Jul 10, 2012 | 05:13 PM
smokin5s's Avatar
I meant to type something up since I just did it myself.... Here is step by step to the best of my memory... I apologize for not having pictures or socket sizes.
Step 1 - remove battery, battery tray, and air box baffles
Step 2 - Put right side of car in the air, remove the wheel and plastic pieces surrounding the wheel well
Step 3 - Drain Radiator and remove Radiator and Fan's (you will need green coolant when you refill it)
Step 4 - Remove Serpentine Belt and tensioner pulley (Belt tensioner is a 14mm)
Step 5 - Unbolt A/C compressor, but leave it connected (this is to gain access to the long bolt under the Alternator)
Step 6 - Unplug the 2 power cables connected to the alternator (negative plug and positive wire held on by a nut and washer)
Step 7 - unbolt Alternator (it is 2 bolts, one is a long bolt accessible under the car once you drop down the A/C compressor, the other is a shorter bolt accessible from the top of the engine bay.)
Step 8 - Pull Alternator out through space created from removing the radiator and fans
To put back together, reverse the procedure.
I know it's a huge PITA, but this is seriously the most simple way I could find to replace it. It also helps if between steps you drink a beer :-)
Old Jul 10, 2012 | 05:14 PM
smokin5s's Avatar
BTW, it's not that bad if you follow my instructions... the biggest PITA was not knowing what to do next in order to get it out... pulling the radiator really helps a ton.
Old Jul 11, 2012 | 11:11 AM
pktaske's Avatar
I really appreciate you taking the time to type this out. I'll come back after I'm done and add some pics and bolt sizes.
Just for my own curiosity, did you end up getting a brand new OEM from Nissan, a used one, Pep Boys, etc. and how much? Thanks....
Old Jul 11, 2012 | 11:27 AM
phatboislim's Avatar
holddddddddddd up buddy...if the 6th gen is anything like the 4th and 5th gen, i'm 99% sure that the draining/removing of the radiator and fans is unnecessary. i dont know where the battery is placed so i cant comment on that other than the removing of the terminal. but the alternator can be dropped in way under an hr w/ just removing of the compressor, moved to teh side and dropping the alternator.
Old Jul 11, 2012 | 11:30 AM
gatsugansu's Avatar
Easy Breezy. Open you hood and look around. Go to library and get Chilton Manual. All these noobs expecting to be spoonfed!
Old Jul 11, 2012 | 11:48 AM
smokin5s's Avatar
dude, I spent 2 hours trying to move the compressor to the side, I couldn't get it through and busted up my hand pretty good trying. not saying it couldn't be done, but it was way easier removing the radiator and a lot less frustrating... it was worth the 20 dollars I spent in coolant to relieve that frustration. (The radiator removal took less than 10 minutes) Also remember the 4th and 5th use the 3.0 instead of the 3.5 (not including the 5.5 gen) so the motor layout is going to be totally different)
as far as what Alternator I used, I picked up a refurbished from Autozone with a lifetime warranty for 199 with 35 dollar core charge.
Old Jul 11, 2012 | 11:49 AM
pktaske's Avatar
Either your being sarcastic (in which case I'll give you a chuckle) else your a total D-Bag. Pop up the hood on your 2006 and tell me if you see any sign of an alternator. This guy just saved me a bunch of time telling me the basic steps involved here. It's called helping someone out.
Old Jul 11, 2012 | 11:53 AM
smokin5s's Avatar
dude, isn't that what this forum is for is to help each other? I wish I would have had some sort of instructions written up on how to do this before I opened the hood and fought with it. At the end of the day, I got it done, but I don't see what the problem is with this guy asking if anyone has done this before and has tips or tricks to make the job easier....
Old Jul 11, 2012 | 11:59 AM
it's not totally different, the motor layout is basically the same. with the plastic shield out the way from the bottom, it's pretty simple to drop the alternator w/ the compressor to the side. completely removing the 4 bolts form the compressor. unbolt the alternator and pull it out. so the compressor line wont have pressure on it, place it back up there gently where the 'holders/platform' for the compressor sits and get your alternator ready to throw back up there. and i have big *** hands. so it can be done. anyone have a pic from the top and bottom of a 6th gen setup?
Old Jul 11, 2012 | 12:22 PM
smokin5s's Avatar
whatever works man, just giving the steps that I took in order to be successful. not say there isn't other ways to do it.
Old Jul 11, 2012 | 12:29 PM
aackshun's Avatar
...anyone have a pic from the top and bottom of a 6th gen setup?
It's the same as every maxima since 95.......
95-08 Maximas use the same general procedure for getting to the alternator..... Even 09+ if I think about it... I've only seen two though and I wasn't looking @ the alternator
Old Jul 11, 2012 | 12:35 PM
annnnnnnd there you have it..save your coolant and blood.
Old Jul 11, 2012 | 09:55 PM
gatsugansu's Avatar
HERE!
Old Jul 12, 2012 | 06:01 AM
pktaske's Avatar
This thread is going the way of mindless forum babble.
Of course I searched beforehand but there was nothing comprehensive I could find. What Smokin gave me was dead on with what Gats "helpful link" (below) said but oh so much more descriptive. Props to guys like him and @$%& the naysayers. We should have all good walk-throughs pinned in The Garage. I will add pics when I am done this weekend.
BTW - read below - says REMOVE RADIATOR.
"The book for my 2007 maxima says: 1. Disconnect the negative battery terminal. 2. Remove radiator. Refer CO-13, "Removal and Installation" . 3. Remove the drive belt. Refer to EM-13, "DRIVE BELTS" . 4. Remove idler pulley. 5. Remove the generator adjustable top mount, using power tools. 6. Remove the generator lower bolt and nut, using power tools. 7. Disconnect the generator harness connectors. 8. Remove the generator upper bolt, using power tools. 9. Remove the generator. I would assume the Haynes manual is saying that if you unbolt the compressor you can avoid removing the radiator. "
Old Jul 12, 2012 | 06:03 AM
i'm telling you removing the radiator is not necessary. you can do it, but it's not necessary.
Old Jul 12, 2012 | 06:20 AM
pktaske's Avatar
I'll most certainly report back.
Hree's a funny: I called Nissan in East Windsor. They qouted me $451 for JUST the alternator! AN ALTERNATOR!!!!!
Old Jul 12, 2012 | 06:30 AM
lol its an hr job from start to finish when i did mine..i didnt even have a lift..jack and jack stand, with all hand tools...tell them FOH
Old Jul 12, 2012 | 06:57 AM
pktaske's Avatar
Dude - That was for the PART!!! Labor was another $200!! I called another place in Freehold and sure enough that was spot on. The guy at the second place said "Don't buy it here - they are all remanufactured anyway".
Imagine paying $650 to get an alternator put in? That's why these forums are so great.
Old Jul 12, 2012 | 07:09 AM
that's bananas. i'd have to be unable to replace it to pay that much. i'll suck up a weekend w/ beer to do that instead of paying that much
Old Jul 12, 2012 | 09:40 AM
DAlastDON's Avatar
That is pretty much what i did but i only relocated the radiator because i did not want to fool with the CVT cooler. I removed the battery and put it there next to the CAI.
Be sure to loosen the nut on the idler pulley before attempting to loosen the belt. To get to the tensioner adjustment it helped to have a universal joint on the socket extension. When tightening the belt, start the car, then tighten the belt a little more if it squeals. Have the AC on full blast when you start the car. Be prepared to make adjustments to the belt tension if it starts squealing in a few days.
Old Jul 12, 2012 | 02:05 PM
aackshun's Avatar
For future reference, PM me if anyone wants to buy an alternator for their 6th gen
Old Jul 12, 2012 | 05:45 PM
smokin5s's Avatar
Good call, don't want to forget to loosen that nut. I completely forgot to mention that.
Old Jul 12, 2012 | 09:12 PM
DAlastDON's Avatar
If you have amplifier's, now would be a good time to beef up the wire from the alternator to the battery.
Old Jul 15, 2012 | 10:28 PM
smokin5s's Avatar
did you ever get your alternator swapped out?
Old Jul 15, 2012 | 11:39 PM
NIKV69's Avatar
I got an brand new OEM alternator from Spider marine for next to nothing and did it myself recently. You have to take the radiator out. No need to touch the AC compressor. It's a breeze except for that long both with you have to fiddle with but I did it in an afternoon with new hoses and coolant and belts.
Old Jul 16, 2012 | 12:47 PM
smokin5s's Avatar
thank you
Old Nov 30, 2025 | 09:31 AM
fowlerjdeanna13@gmail.com's Avatar
Thank you for the information
My husband want to junk the car because the job is so big he's not a moto head. He's a builder.
So he hate working on vehicles.
Old Dec 1, 2025 | 07:34 AM
RA030726's Avatar
I'm nutty for Nissans
Old thread, lots of wrong info.
The 6th gen uses a different subframe that wraps around the engine. It's in the way. I don't see how any 04+ can get the alternator out without removing the radiator. Earlier years have a center crossmember and more room to drop it out the bottom.
PH98I30
19
Jun 13, 2016 02:38 PM
Balkins
Feb 1, 2016 12:45 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
