AC weak, stopped working, started again?
Old Aug 27, 2012 | 07:31 PM
Kryogen's Avatar
Presure is ok
rad fan spins like crazy when ac is on, normal?
whats the issue?
Old Aug 27, 2012 | 10:00 PM
ATL's Avatar
ATL
weak as in weak air movement? or just not blowing very cold air? the air cycling on and off, and the air not blowing very cold are both direct indications of low pressure. may want to double check your gauge readings. only other thing that would cause it to cycle on and off could be the clutch going out. but that wouldnt keep the air from blowing cold when it did work
Old Aug 27, 2012 | 10:31 PM
Amerikaner83's Avatar
radiator fans are supposed to blow when your AC is on, so yeah that part's normal.
manually force the AC to high...does it work right? Or do you have auto climate control?
Old Aug 28, 2012 | 01:42 PM
dee.signs's Avatar
Stupid hose!!
I had an 04, and my 07 both have/had a leaking low pressure hose. It is the hose where you charge the a/c. Look closely around the compression fittings of the hose. If it looks like there is oil or grease surrounding the crimp there is a leak. The part for my 07 is about 100 bones and 15 minutes of time for the labor. THen you have to recharge...
I am picking up my part tomorrow, doing the work over the holiday.
Old Aug 28, 2012 | 08:33 PM
Kryogen's Avatar
wasnt blowing very cold lately so I got a walmart kit to try to refill... presure seemed ok according to gauge. did a mess with the kit. Seems worse than it was before. wasted 50$.
I think I'll have to go to the dealership to have it checked and properly taken care of.,..
Old Aug 29, 2012 | 02:45 AM
dee.signs's Avatar
Chech that hose. Its an easy fix.. dealer will charge 400 dollars...
Old Sep 3, 2012 | 06:02 AM
Kryogen's Avatar
no oil around hose, #1 clean
Old Sep 4, 2012 | 02:28 PM
Kryogen's Avatar
soooo? compressor is dead ?
Old Sep 6, 2012 | 07:26 PM
Kryogen's Avatar
works #1 when it works, blows damn cold.
works half the time.... sometimes super cold, sometimes suoer hot.
Balkins
Feb 1, 2016 12:45 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
