Can i drop my 07 max with the stock wheel and tire
Old Sep 24, 2012 | 07:29 PM
MAXED OUT KID's Avatar
HI ,
i have a 2007 maxima sl with 17's on 225 55 continental dws tires i wanna drop it without changing tires since i just bought them .. i wanna know if i get s tech tein or progress springs am i gonna rub ? i would like to keep these tires for winter and when summer rolls around i can get new wheels and tires ......
HELP ME !!! THE NEW B IS LOST !!!!
Old Sep 24, 2012 | 07:36 PM
You'll be fine.
Old Sep 24, 2012 | 07:55 PM
coolsun's Avatar
no rub cause your tires are narrower compared to stock SE 245/45/18
Old Sep 25, 2012 | 02:24 AM
THANKS !!! looks kind of tight .... much appreciated though ...now i can proceed weeeeeeeeeeeeeeeee !!!
Old Sep 25, 2012 | 05:59 AM
mrjasonlyrics's Avatar
It might seem like a good idea to change the springs and not the shocks/struts but by doing that you'll actually be reducing the actual life span of the stock shocks/struts. The KYB GR-2 are very cheap on ebay and you have a piece of mind that you won't have to go back under there to replace your shocks/struts and/or get another wheel allignment after you lower it.
I have the Canuck lowering springs 1.5" front and 0.5" rear and it supports my application for my 22's, 18's and my 17's snow. I don't have to worry about the lowering when I switch wheels
Old Sep 26, 2012 | 01:29 AM
thanks kid i got those kyb gr2's already ...just was looking for the right spring im gonna try the teins ...plus i got new struts mounts and that racingline tower strut bar .. how good is that strut bar you really feel a big difference with it ??
Old Sep 26, 2012 | 02:33 AM
Ok I see. You won't feel any major hangling by just adding a strut tower bar, well I don't. Unless your car is slammed, you have front and rear sway bars and a rear upper strut tower bar that's the only way I can see any improvement in the handling. Our cars are just too big. But it does look really cool though...
Old Sep 26, 2012 | 08:41 PM
[QUOTE=mrjasonlyrics;8618039]Ok I see. You won't feel any major hangling by just adding a strut tower bar, well I don't. Unless your car is slammed, you have front and rear sway bars and a rear upper strut tower bar that's the only way I can see any improvement in the handling. Our cars are just too big. But it does look really cool though...[/QUOTE
yeah i seen them on cars they look sweet ..by the way would you happened to know how eibachs ride ....? and do springs drop more then what they say there
gonna drop from the consumer ? lets say 2in f and 0.8 r ...one more question
my stock wheels and tires 225 55 r17 they wont rub when cut the wheel ...or would they ? im going nuts with these springs
Old Sep 26, 2012 | 08:42 PM
Old Sep 27, 2012 | 03:21 AM
The Eibachs are a good drop because it doesn't drop too low in the rear which will cause rubbing. On the 6thgens the rear is naturally lower than the fromt so it will take that stress away. I have the Canuck 1.5" front and 0.5 rear is perfect for "me" I have 350Z wheels with with snow tires, can't remember the size but it fills the gap pretty good.
Don't lower your car and not get a camber kit before you do an allignment. Don't believe guys when they say they lowered their cars and didn't do a camber and their tires don't have camber wear. You may not see it with a naked eye but it's definitely recommended or you'll be changing tires yearly. I could be wrong but a 225/55R17 is equivelant to a 245/45R17 and you should be fine on stock 17's
I don't have any pics with my application because I bought them this year during the spring and my car is at the mechanics getting another motor swap. Blew it again
Old Sep 27, 2012 | 04:53 AM
datdude20's Avatar
coilovers
Old Sep 27, 2012 | 07:05 AM
Originally Posted by datdude20
coilovers
Coilovers is for the race track, not intended for daily use. The coilover with dampeners are good but it's about a G. 6thgens are the heviest of them all and I gauranty within a yeah your suspension is done and you'll be boucing around like them Honda guys
There's a right and wrong way to do things and putting coilovers on a 6thgen is wrong
Old Sep 27, 2012 | 07:11 AM
datdude20's Avatar
thats false.....my previous 4th gen had the same k-sports for 3 years before they blew
my last 5.5 gen had used jic coils for 2 years and before i sold the car they still rode like a champ and my current 4th gen has had BC coilovers for 2 years ...smooth as butter over here
and i drive my cars daily ......soooooooooooooooo
the reason coilovers blow quick is because people make the mistake of wanting to slam the car as low as possible and make them as stiff as possible.....
Old Sep 27, 2012 | 07:43 AM
Understand what I'm trying to say. Regular coilovers (not the real coilovers with dampeners) on a 6thgen is a no no. A 4thgen and 5.5gen is way lighter than a 6thgen. The reason people put coilovers on their cars is because they have intenstions of slamming it and it's cheap. If you don't intend to slam your car why use coilovers it in the first place. Coilovers are suspension killers in disguise.
I use to be that guy who said coilovers are good because you can adjust them in the winter but when you raise it you offset the camber which will result in tire wear, so to prevent that you'd have to do an allignment evey time you lower or raise the car to suit the application. Get a comfortable straight drop according to your rim size and application and don't worry about touching it again.
Old Sep 27, 2012 | 07:55 AM
gatsugansu's Avatar
WOW! Strong opinion here!! Been sitting on BCs for a while love the ride and adjustability. Have you actually tried any coilovers yourself?
Old Sep 27, 2012 | 07:59 AM
ShocknAwe's Avatar
I agree when it comes to pillow-ball mounts and city driving. If you live out in the burbs then CO's will be fine on a DD. CO's ARE made for the track so they are pretty damn strong. Dont get a pillowball mount and they should never break down
Old Sep 27, 2012 | 08:30 AM
gatsugansu's Avatar
HI ,
Maxima.org is a great site with wealth of information. It has been around for long time almost all questions Newbies have been answered. Contrary to popular belief, nobody likes a newbie who fails to do research.
dank4us
34
Jun 10, 2024 03:45 AM
homeyclaus
Sep 3, 2015 06:15 PM
cheftoo
Aug 24, 2015 09:20 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
