Changed Headlights, Car wont start now
Yesterday I changed out my stock D2s bulbs and ballast for some morimotos. I started the car twice throughout the process to keep the battery good. (I was listening to music the whole time) The car started without no problems. Once I had everything back together I tried firing up the car again and no luck. It turns and turns but won't fire up. Now to throw in a side note I did by accident hit a terminal on the battery causing a spark right before I tried starting it the last time. Also when I turn the key the accessories the radiator fan goes into high and stays on every time. I also hear a click coming from the engine bay. The battery is new, I bought it 3 weeks ago, the headlights, signals and radio all work. Checked all fuses and are good
Here's a video of what going on. Please excuse me in advance for the shotty camera work and lighting as I just made this video. Its more so for sound
Any suggestions Please feel free to chime in
Not sure, try leaving the battery disconnected for an extended period of time, maybe everything will reset. I'm not sure what would turn the fan on like that, unless it somehow thinks it's overheating or something?
I'm going to go disconnect it now and I'll check back in a hour or so to let you know if it worked or not.
Ouch. If you really want your car you should take it to a mechanic, hopefully it's something he dealt with before or he can tell you exactly what it is and if it's a DIY fix. It can't be the battery because it's attempting to start, the engine wouldn't even crank if it was. Maybe it's in some kind of safe mode and by not allowing the car to start it's probably doing you a favour.
Originally Posted by NismoMax80
Did you check your fuses in the engine bay and under the steering wheel? Can you test your battery voltage?
Sent from the batcave
screw disconnecting over night. turn on your headlights, disconnect terminals from battery, take the negative terminal and touch to positive terminal. Any residual voltage will discharge in the headlights. everything will reset.
ah the unorthodox...
How do you know you blew the computer? IT can be a simple bad ground somewhere. Had same issue where car would crank and not start.
If all fuses are good i doubt the computer is blown, might be some other issue your mechanic overlooked.
Although you can try getting another ECU, but i doubt that will solve your problem. You'd have to really screw up to fry the computer.
I shorted the + terminal on the alternator which blew the main fuse on the battery. Fuse cost me $20 from dealer. Shorting out battery terminals is not enough to kill anything in the car. That's why there is the main fuse on the battery for. For the radiator fan, do you mean does it turn on right away when he turns the key? Did he check the fan relays? Is his climate control module hooked up?
It really depends on WHAT he shorted to. If you apply too high of a voltage to something that goes straight to the ECU, then yes the ECU can go bad. And yes, if it's just the battery terminals it's unlikely (although possible) the ECU is bad. It's unclear what exactly was shorted...
I'm pretty sure its some other electrical problem, its unlikely the computer is dead. OP, pull out one sparkplug, insert it into the coil and see if the car fires a spark while cranking. If it does not, bad ground because i had that issue on my 6 gen.
If he really fried the computer, the airbag light should not come on , not even blink or just stay lit all the time. Besides, how can he send high voltage to the ECU while changing out the headlights?
By going bad it doesn't have to be dead, just not functioning properly. He said he shorted something and there was a spark, but like I said it's not clear what exactly happened. I don't know how the ECU works, I'm just speaking from a general electric point of view. If you send 12V to something that's expecting up to 5V, you'll damage that component. I'm not saying whether his ECU is bad or not, just that I wouldn't exactly rule it out.
OP should diagnose more areas before dumping money into not well though out problem.
Right, but there might be other factors like maybe he shorted something that's part of the injector circuit causing injectors not to send fuel to the combustion chamber or maybe the spark not firing or both or fuel pump not working.
Thanks everyone for the input.
Today I went to talk to my mechanic and I he showed me the ECU. I didn't see any obvious signs of it being fried however, he did have me smell it and it definitely had a burnt odor to it. The new should be in tomorrow so hopefully that'll be the end to this costly screw up. I'll keep you all posted
False.
If you dont think it is possible to fry an ECU then you have problems ahead of you. ALWAYS remove the negative when doing electrical work, if the OP had done this it probably wouldnt have happened. It takes 5mins. Kind of like jack stands. Most of the time it does not matter but the time it does you are in serious trouble
I had a related issue on my '04. Decided I wanted to put LED's in the integrated fog lights. They did not work, and in disconnecting a wire to the fogs, saw a very small spark. Now both fogs (back to the stock bulbs) do not work. No blown fuses, and the bulbs still look good. Any answers?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
RealityCheck
Aug 5, 2015 06:18 AM
