remove front side carpet instructions?
Old Oct 7, 2012 | 04:54 PM
hpl912's Avatar
Nothing came up in the search so i thought to ask here.
where can i find instructions to removing the front seats and carpet?
The purpose is to access and repair the rusted floor pan
thanks in advance.
Old Oct 7, 2012 | 09:16 PM
DAlastDON's Avatar
Disconnect the battery first and wait at least 20 minutes before you start. There are air bags in the seats. Should be a pretty cut and dry procedure. Remove the four nuts on the seat rails, disconnect any wires, then remove the seat. The trim panels just pull off. Start from the front and work your way back on the door sill plate. If you have to remove the center console, there are two hidden screws accessible from the back seat that are located near where the front seat belts anchor down. The rest should be obvious.
Old Oct 8, 2012 | 12:31 PM
joecurr's Avatar
I don't know how many times I've posted this recently, the FSM's should be stickied lol. Look on page EI-40.
http://www.nicoclub.com/FSM/maxima/2005_Maxima/ei.pdf
You'll also have to reference other sections of the FSM.
Old Oct 11, 2012 | 09:31 AM
hpl912's Avatar
thank you guys for the info.
@DAlastDON: is it really mandatory to unplug the battery before unplugging the seat's airbag plug? If it's not done so, the airbag will deploy or malfunction afterwards?
Old Oct 11, 2012 | 09:49 AM
philpoe's Avatar
4 Maximas and counting
Our of curiosity, is your rust centered around either of the front door jambs, or somewhere else? Do you know the root cause of the rust?
I have rust, only on the front passenger side, near where the front door jamb is. I am now suspecting that it has to do with the sunroof drainage system, which dumps water in that location, and is perhaps clogged, causing pooling, and in turn rust.
thanks in advance.
Old Oct 11, 2012 | 10:57 AM
hpl912's Avatar
there is a picture of the rust i posted here: http://forums.maxima.org/6th-generat...st-anyone.html
i don't know the cause of the rust i'll having it welded a new sheet of metal. if you know the cause and if it's the exact same spot, let us know!
Old Oct 11, 2012 | 04:36 PM
joecurr's Avatar
Yes, yes, and yes. Do NOT touch anything that has to do with the airbags until you've disconnected the battery and given enough time for capacitors to discharge. You want the car to have absolutely no power when you plug or unplug any airbag connectors. Actually, you should get in the habit of disconnecting the battery in general when you do electrical work, including anything that involves plugging and unplugging any connectors. It's better to be safe than sorry.
Old Oct 11, 2012 | 04:50 PM
philpoe's Avatar
I see the picture, but don't know where it is relative to the car.
The answer that Porky gave in the other thread made me try to think this through about drainage.
Looking at the sunroof drain diagram in the FSM has me convinced that the problem is somehow related.
Old Oct 12, 2012 | 07:55 AM
hpl912's Avatar
thanks for the reply.
So after i have removed the seat, can i simply plug the main battery back? will it affect other airbags still connected? or should all airbags need to be disabled in preference since one is disconnected?
the situation is that i need to remove the passenger seat by myself and then drive to the garage for the floor pan repair.
Old Oct 12, 2012 | 11:47 PM
DAlastDON's Avatar
That is a good question. Worst case scenario is that the car detects a fault in the airbag system and the air bag light comes on and has to be reset with a consult2 or equivalent scanner. The rest of the air bags will function properly.
Old Oct 13, 2012 | 08:37 AM
mrjasonlyrics's Avatar
You'll have to go to the dealer to reset those codes. Are you going to attempt this yourself? I hope you have the right tool because you'll be back on the org asking what you need to get the job done
Old Oct 13, 2012 | 10:27 AM
hpl912's Avatar
thanks guys.
actually to save some trouble i just left all plugs intact and only removed the seat bolts and move it backwards. Luckily there are plenty of space to work on the floor pan and cables are long enough without having to disconnect the plugs and taking out the seat
homeyclaus
Sep 3, 2015 06:15 PM
Stelianos
Aug 19, 2015 02:07 PM
kirkhilles
Aug 8, 2015 10:53 AM
13Maximasv
Aug 7, 2015 10:56 AM
BassAddictJ
Aug 4, 2015 11:38 AM
