Front end trouble, looking for advice/mechanic in NY/NJ area that knows 6 Gen
Old Oct 13, 2012 | 03:04 PM
03maxsiny's Avatar
Hello everyone,
I own an automatic '05 SL, and I am having some issues with it, and would like to know if anyone could recommend me someone in the NY/NJ area that knows the 6th gen well. I have a problem list that I would like to tackle, and am on a budget, so help is appreciated. Some problems I am having are:
- sound at idle, varies with wheel turn (steering pump?)
- vibration & clattering, worst between 65 & 75MPH, worsens with banks to the left
- front end feels "loose"
- occasional click under hard acceleration
- belt squealing/intermittent catching while turning (while car is cold)
- squeaking & scraping during slowdown (from front left side)
- heat blows cold air
- timing chain tensioner rattle while cold
Hopefully I would be able to reproduce the problems during a test drive, but if anyone has any advice, I appreciate it. Thank you so much in advance!
- Nick
Old Oct 27, 2012 | 03:14 PM
04BlackMaxx's Avatar
Originally Posted by 03maxsiny
Hello everyone,
- Nick
- Heat blows cold air - I had this happen and fixed it with a $80 part - Usually the problem is the blower motor amplifier (or fan control amplifier or fan resistor). The amp is located on the blower motor box behind the glove box.
Here are the instruction to replaced the amp on the early models, although the models are different the component locations is similar. 2000-2003 Nissan Maxima Blower Motor Amplifier/Resistor Replacement Procedure
Old Oct 27, 2012 | 03:30 PM
Mrbizness1's Avatar
I have been here a few times for SES light problems. He installed a knock sensor without removing the intake manifold in 15 minutes. He had me buy the part on ebay. He saved me a few bucks.
http://www.maximumtuning.net/
Old Oct 29, 2012 | 05:53 AM
nsnrider's Avatar
sounds like the first thing you have to do is have the car put on a lift and check your front end. The clonking, and noise coming from front end might be due to wheel bearing, lca, sway bar links, etc.
timing chain noise is probably do to faulty chain guides, get those replaced, problem solved.
no heat could be a few things, does your blower fan work? if yes, check your coolant level and your hoses for circulation.
Old Oct 30, 2012 | 12:14 PM
Max streets's Avatar
Im in the bronx i now some affdorable mechanics around my way .Off of your list the most expensive repair is the timing chain with tesionar, u have check lower control aems 6 gen control arms are weakl they brake easy and all of the above
rtirbany
Sep 8, 2015 11:46 AM
JoshG
21
Sep 4, 2015 09:04 PM
Samedi
Aug 12, 2015 01:54 AM
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
