2005 Maxima SAT Sirius reception problems.
Old Oct 16, 2012 | 03:55 PM
BLCKMAX's Avatar
So I bought an awesome 6spd smoke/black fully loaded 2005 Maxi ...
It has a factory SAT button including an antenna that is behind the the rear glass by the roof. Anhow, I activated it today, however it only works 10-20 percent of the time. It is aweful! no reception anywhere maybe constant 20 seconds max before it searches for signal....
Any suggestions/comments would be greatly appreciated.
Old Oct 16, 2012 | 07:13 PM
po8pimp's Avatar
Had this happen in my 07 Escalade. Turned out to be the antenna was not all the way plugged into the transmitter/receiver. Mine was located behind the glove box. Don't know location on the Max.
Old Oct 18, 2012 | 09:09 PM
BLCKMAX's Avatar
Thank you! I'll look at the glove box ... No one else on this forum can't relate
Old Oct 18, 2012 | 09:55 PM
po8pimp's Avatar
http://forums.maxima.org/6th-generat...t-install.html sounds to me from reading this thread that it is in the trunk under the rear deck lid. Go into your trunk and remove the trunk headliner where your back speakers are and the module should be in there. Make sure everything is connected securely. Hope this helps.
Old Oct 20, 2012 | 06:38 PM
BLCKMAX's Avatar
Thanks for the reply... So I did what you said to do ... I looked around all teh connections everything seems to be intact. Still no idea ... maybe will go to a car audio place see what they say, I cannot beleive that no one else had this issue
Old Oct 21, 2012 | 05:39 AM
boatguy272's Avatar
are you saying the antenna is inside or outside the car?
Old Oct 21, 2012 | 08:00 AM
BLCKMAX's Avatar
the antenna (facotry) is outside ... its factory!
so weird, i cannot figure it out.
Old Oct 26, 2012 | 02:58 PM
BLCKMAX's Avatar
anyone?
Old Oct 26, 2012 | 04:33 PM
po8pimp's Avatar
have you called nissan yet? Some service reps are nice and will give you pointers on what to do. I would call around and explain what you are experiencing and ask where the antenna connects to?
Old Oct 30, 2012 | 03:48 PM
BLCKMAX's Avatar
I see ... I will try it ... Next option is to take it to the stealer
or maybe local audio tuning place ....
Lakersallday24
Nov 7, 2024 07:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
wingnut2006
Aug 15, 2015 04:16 PM
cmpowell86
Aug 10, 2015 12:35 AM
criminalslang810
Aug 9, 2015 03:35 PM
