06 Max throttle hesitation and rev after let off
Old Dec 3, 2012 | 09:43 AM
Ritz's Avatar
Got a friend with a 06 Maxima with only 40k miles on it. It's a 6 speed manual. When accellerating (any gear it seems) it kinda hesitates or lags for a few seconds like it's not getting fuel, and then eventually goes like it should. Also when letting off the gas to shift gears the RPM's don't drop, almost like you kept your foot on it. It even revs up a few hundred RPM's most times.
Any ideas what the problem could be? I was thinking maybe pedal position sensor, but there's no check engine light. I'll see if I can get a scanner on it to double check.
Old Dec 4, 2012 | 08:27 AM
L36's Avatar
L36
It might be the pedal position sensor. CEL does not get triggered instantly, you might have symptoms without a CEL.
Old Dec 5, 2012 | 10:23 AM
Ritz's Avatar
yeah, that's exactly what I was thinking.. just waiting to see if the light comes on.
any other possibilities? it might be a few days before I can try to put a scnaner on it.
Old Dec 5, 2012 | 10:25 AM
Ritz's Avatar
just re-read my original post.
to clarify, when letting off the gas to change gears it revs up a bit for a couple seconds and then drops like normal.
Old Dec 5, 2012 | 07:21 PM
L36's Avatar
L36
Crankshaft sensor is a good candidate for this as well.
bryants95max
Oct 2, 2015 12:52 PM
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
