intake manifold spacers ?
Old Jan 3, 2013 | 06:09 PM
Pinto's Avatar
ive had these for a while now but in the back of my mind it bothers me
the member i bought them from sugested to use a small amount of rtv on them. i did reluctantly even tho when i used simliar spacers in the past on other cars i never did.
when i installed naturally some rtv squeezed up and in the runners i could reach i wiped out the excessive. im pretty sure some spots i couldnt get too
does anyone with intake manifold spacers use rtv? do they seal fine without? i have no problem redoing them and maybe throw in some new coilpacks as preventive maintence
Old Jan 3, 2013 | 06:34 PM
ShocknAwe's Avatar
I have never seen spacers that you dont have to RTV....THe point of them is you can use RTV instead of having to buy a new gasket each time. I would highly recommend using RTV because even the best spacers are not perfectly flat nor is the mating surface. Air leaks suck, I know from expierence
Old Jan 3, 2013 | 07:25 PM
Pinto's Avatar
That eases my mind some then
Old Jan 3, 2013 | 07:28 PM
ShocknAwe's Avatar
Its hard to make RTV look pretty, the best you can do is match colors. The real pain in the *** is having to get old RTV off. good luck amigo
Old Jan 4, 2013 | 12:52 PM
Rods03Max619's Avatar
I used RTV on mine but not alot just minimal to get a good seal.....
Old Jan 4, 2013 | 01:39 PM
Pinto's Avatar
ha yea i use black all the time unless i need copper for exhuast stuff. i def used as little as possible. it just bugs me out when i see it squeeze into the runners and the point is to get a very smooth flow. so i used a long think screwdriver or whatever tool to get as much excesse on the inside as possible
Old Jan 4, 2013 | 03:53 PM
7speed's Avatar
sounds like you used to much.
Old Jan 4, 2013 | 05:47 PM
twentyeggs's Avatar
RTV is a must for spacers
Old Feb 6, 2013 | 09:03 PM
MajorReflexes's Avatar
sorry to be a newwb but what are spacers used for iv been seeing alot of them on the org
Old Feb 7, 2013 | 04:07 AM
aimeedogs's Avatar
that right, i used a long think screwdriver or whatever tool to get as much excesse on the inside as possible,thanks
Old Feb 7, 2013 | 07:13 AM
NmexMAX's Avatar
dot dot dot ...
For the main LIM/IM spacer, you CAN use 2 OEM spacers one on top and one on bottom, for the rest, not sure if that's feasible.
I did this because I'm always removing my IM for some weird reason, and getting the spacers and RTV off becomes a PITA.
aw11power
Oct 10, 2021 04:57 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
JonBlz
Oct 5, 2015 06:02 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
