Anti Freeze leak
Old Jan 17, 2013 | 12:33 PM
BETO6700's Avatar
Anti Freeze leak
For the past 2 months my car is leaking anti freeze, it only leaks overnight. If I drive the car during the day and park it on a clean area there is not leak , if I leave it on the same place the following morning there is a 3 inch spot. The radiator is always full but the reservoir has to be refilled
I checked every where, the only place i found some was on the lower control arm but cant determined where is coming from..Any ideas where to look??
Old Jan 17, 2013 | 04:29 PM
Terrentius's Avatar
I would keep looking around the reservoir and all the way to the control arm. It is there. If you do not fill up/top off the reservoir, does it just empty out?
Old Jan 18, 2013 | 09:05 AM
BETO6700's Avatar
I did not think of that! I wont refill the reservoir and check the radiator to see if it goes down.
Old Jan 18, 2013 | 02:58 PM
Terrentius's Avatar
Yeah, I had one crack on me once. They're plastic, so they can crack over time and leak coolant. That might be your issue.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
vrajesh123
Sep 22, 2015 04:20 AM
