Need some advice on p0300 problem
Old Jan 24, 2013 | 05:40 PM
mikejhath123's Avatar
Hey guys, I have a 04 maxima automatic trans. Trying to get it to pass emissions. I keep getting a p0300 code. Took it to the dealer they told me I needed all new coils and plugs. Somebody put aftermarket coils on it previously. So I put oem coils and plugs in. No change. Went to alldata and started doing diagnostic checks... Checked the fuel injector resistence, changed egr valve oem, changed maf oem, borrowed a buddys smoke machine no vaccume leaks found. So I took it back to the dealer and they said it needed two bank 1 af sensors, and only put. Sensor 1 in due to the fact I needed a new cat installed. So I baught two converters from advance and put them on cleaned the flex pipes really good and put 3 other ntk sensors in. I still have the same problem. I looked at various sites tried to do a ecu reset, idle volume relearn with the gas pedal.. I did get codes p1281 and p1283 before but since I changed the sensors they haven't come back. The idle bumps up and down from 638 to 700 when it does I noticed the car changes from closed loop to open loop. The short term fuel trim for bank 1 is -25 and the short term fuel trim for bank 2 is 25. And long term fuel trim for bank 1 is -1.6 and long term trim for bank 2 is -3.4. Is there any other ideas or thoughts about this? I'm afraid to take it back to the dealer, the first time was a waste.
Old Jan 24, 2013 | 07:00 PM
Terrentius's Avatar
You've changed out some stuff. So, if the old stuff is what possibly gummed her up, then I am thinking you gotta un-gumm her. I would seafoam her and take her for a long highway drive. Maybe that will clean out the pipes a bit, so to speak, and get you your pass on the emissions test.
Old Jan 24, 2013 | 08:22 PM
L36's Avatar
L36
Check your grounds, make sure they're clean. Had something similar after engine swap in my 04. Bad grounds were to blame.
Old Jan 25, 2013 | 05:27 AM
Terrentius's Avatar
Yup, L36, is pointing you in the right direction Make sure them grounds are clean and tight. This is, unfortunate, a process of elimination, as you have witnessed by how the dealership is treating you, until ya find your particular issue.
shilov
Feb 19, 2024 09:40 PM
Lilfatz301
Sep 18, 2015 08:06 AM
14GmMax
Sep 17, 2015 09:08 PM
hntwhttail
Sep 12, 2015 03:43 PM
2012Maximus
Sep 10, 2015 12:50 AM
