Help finding A/C leak
Old Mar 18, 2013 | 09:30 AM
QwikKota's Avatar
The a/c has gone out in my '07, it went out within 50 miles of my warranty expiring, lovely. I have used dye to find the leak but do not see any trace on the exterior lines, compressor fittings or what I can see of the front mounted condenser coil. I fear it is in the dash with the evaporator core and requires taking the entire dash apart. I would like to know that is the case before doing it or taking it to a shop. I have kids and the heat is already here so need to get this fixed rather fast. Would I not smell the refrigerant leaking if it was inside the vehicle? Thanks.
Old Mar 18, 2013 | 11:32 AM
Costee's Avatar
Well, before you go so deep check the shaft seal of the compressor-- a silent culprit of leakage because it's too tucked away to be seen.
Old Mar 18, 2013 | 12:12 PM
Claybob86's Avatar
I assume you did, but will ask just to verify, you had it recharged when the dye was added, correct?
Old Mar 18, 2013 | 12:49 PM
QwikKota's Avatar
Yes, I used the dye that is already added to refrigerant. It was blowing cold when I was done, but did not see any dye on the exterior other than the two ports.
I will try to check the compressor shaft area but like you say hard as hell to see. A compressor or exterior lines I can do myself easily, well, easier than a dash pull.
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
dcam0326
Sep 7, 2015 07:26 AM
