need help on finding the right spacer
Old Mar 27, 2013 | 07:31 AM
Flyguy03's Avatar
hey i have a 2004 converted to a 07 maxima i just got the 09 maxima 19'' rims on there i lowered it on tein springs. the problem now is the rims are not flush with the fender i was told to get spacers for it but i dont know which mm do i need i was told 25 all around is that true help me maxima GODS
Old Mar 27, 2013 | 08:54 AM
You'll need bigger spacers for the rear than the front. Take some measurements. 1" = 25mm.
Old Mar 28, 2013 | 06:04 AM
Flyguy03's Avatar
ight cool thanks bro
Old Mar 29, 2013 | 09:09 AM
HMAX08's Avatar
the 6th gen will need a +30 to sit flush front and rear. Now those 19's are a +50. HELLA HIGH. I know this because i had the infinity M45 sport wheels, seen in my sig that too had a +50 offset. to sit flush I would go with a 20mm spacer. If you want a nice tiny tiny poke (thats what she said) you can go with the 25mm.
I used 15mm because i didnt care for super flush, LOL. Good day to you sir and good luck
EDIT - i will never buy wheels again with that high of an offset. thus i dont own those anymore
Old Mar 31, 2013 | 06:26 PM
757golfnut's Avatar
20s
06 Maxima
Are 20 inch rims to big and what issue's will I come across.
Help Please!!!!
Old Apr 1, 2013 | 05:13 PM
Flyguy03's Avatar
So 30mm spacer I shud use them on all 4 tire
Old Apr 1, 2013 | 06:38 PM
chrisNYLI516's Avatar
Do you always need spacers when you replace the springs? I have 19in rims all around planning on dropping it with teins springs
Old Apr 2, 2013 | 07:36 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by chrisNYLI516
Do you always need spacers when you replace the springs? I have 19in rims all around planning on dropping it with teins springsSpacer "needs" depend on offset.
Not with the right offset.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
In short, numerically high offset sit more in, lower sit further out. +28-30 should sit well with an 8 or 8.5" wide wheel.
Originally Posted by 757golfnut
20s
06 Maxima
Help Please!!!!
Jesus calm down and do a little research on here. http://forums.maxima.org/tires-wheels-53/
20" wheels should be fine if the overall diameter is close to stock.
http://www.tirerack.com/wheels/tech/...urrentpage=101
Old Apr 2, 2013 | 08:02 AM
Flyguy03's Avatar
so bascially 25 spacer all around or 30 too sit it flush with the fender
Old Apr 2, 2013 | 08:11 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/tires-wheel...recommend.html
pears
Sep 18, 2015 05:25 AM
Vistance
Sep 17, 2015 05:17 AM
Lowered_a33
Sep 10, 2015 09:41 PM
adamgalazka
Sep 8, 2015 01:27 PM
Maxboy23
Sep 4, 2015 06:04 PM
