2006 Maxima overheating
Old Apr 28, 2013 | 01:59 PM
doubleh's Avatar
Hello everyone, I have recently been having a problem with my 2006 Maxima overheating. The coolant level appears to be ok, and I do not think it is the water pump. The car is fine when I am moving, but anytime I stop for awhile or idle the heat jumps up fast. I did notice that the radiator fans are not turning on at all. I think I have narrowed it down to the fuses being bad or the thermostat going out. I know where the fuses are, but I cannot figure out how to pull them out :-( Does the whole green thing come out or do you have to open the clear plastic door and pull them out individually? For some reason, I cannot seem to open the door. If that it not it, where is the thermostat, and what is the procedure for pulling it? Thanks, Doug.
Old May 5, 2013 | 12:03 PM
doubleh's Avatar
Problem solved. It ended up being the fusible link that controls the electric fans and the ingnition switch. Removed and replaced, no more overheating.
Old May 6, 2013 | 03:43 AM
CRiME's Avatar
oem ftw!
Thanks for following up with the fix. Glad you got it sorted out.
Old May 10, 2013 | 06:05 PM
Terrentius's Avatar
Nice follow up, doubleh; you're setting a proper standard.
Old May 12, 2013 | 10:42 AM
Brockster's Avatar
I had this issue about 3 weeks ago. I added antifreeze to the reservoir and the issue disappeared. So, now I wonder if these's a problem with the fuse link? Maybe I should pickup the part. What 's the part number & cost?
wingnut2006
Aug 15, 2015 04:16 PM
follyburr
Aug 12, 2015 08:57 PM
Gsantos79
Aug 8, 2015 07:41 AM
