Does the timing chain wear issue only happen on badly maintained card?
If oil changes were always performed properly, and it wan on synthetic oil since 35K miles, will it develop the issue eventually or it just happens on cars that were not getting frequent oil changes?
Your best bet is to just maintain yours and wait to find out.
It looks like it is a faulty design on this gen though IMO.
I hope that everyone that has had a problem wasn't neglecting their car and then wondering why.
Good luck with your survey.
they can fail on properly maintained engines, but its usually at a very high mileage. that is unless theres a known problem, like KA24 engines had timing chain noise early on from the OEM guides being crappy and wearing
if its not a known problem, you can replace the chain, guides, tensioner, etc when you get around the 250,000-300,000km mark i suppose. usually you'll hear some noises when its going bad though
ive changed one chain myself before, not too bad. on my stuff with timing chains, i dont worry about it until i hear timing chain noises.
Well, from what I've been told by the techs is that Nissan switched either material or supplier for the tensionsers themselves of the 07/08 models, which has resulted in inferior tensioners. It is these defective tensioners that are failing, not the chain itself. So, even on properly maintained 07/08 cars, it is not uncommon for the tensioners fail.
Team STILLEN
Aug 10, 2015 04:29 PM
