Fstb request
Old Jun 24, 2013 | 03:39 PM
DoubleD's Avatar
Fstb request
When I joined the site. I was reading a thread about FSTB. There was a member on here who said he was willing to help someone install it. I live in the burbs of Philly. I'm pretty sure he mentioned he was from the NYC area. I would be willing to make the drive if I could get some assistance with the install.
Old Jun 24, 2013 | 05:18 PM
06BlckMax's Avatar
Really? its 6 bolts Super easy
Old Jun 24, 2013 | 05:35 PM
Fakie J Farkerton's Avatar
Easiest mod ever.
No help needed.
An oil change is hard compared to a FSTB install.
Old Jun 24, 2013 | 05:42 PM
chrome91's Avatar
all you have to do is remove the bolts holding the upper part of the strut, put the bar on, then re-install the bolts. takes like 5 minutes
Old Jun 24, 2013 | 05:45 PM
Kryogen's Avatar
I hope that's a joke?
Old Jun 24, 2013 | 06:04 PM
DoubleD's Avatar
Thanx Guys, I'm assuming I need to be on a totally flat surface. My drive way, is slanted downward toward the street
Old Jun 25, 2013 | 08:51 AM
Machinist's Avatar
Link to Racingline FSTB
http://forums.maxima.org/6th-generat...76976-a-9.html
Install instructions - http://racinglineperformance.com/sho...31_Install.pdf
Old Jun 25, 2013 | 05:45 PM
chrome91's Avatar
shouldnt matter, the strut itself doesnt go loose or anything when you undo the bolts on the strut tower. i cant think of any way a angle affects it
Old Jun 25, 2013 | 06:19 PM
Old Jun 27, 2013 | 08:15 AM
RayRey21's Avatar
simple, simple....if its too much to handle go to a shop.
Old Jun 27, 2013 | 08:18 AM
Amerikaner83's Avatar
you can be at a 45 degree angle, so long as your car is still on the ground.
Old Jun 28, 2013 | 04:42 PM
po8pimp's Avatar
open the hood, there are two covers, one on the drivers side to the rear and the passenger side which goes long the left side. remove them. now there are 6 nuts showing, 3 on the left, three on the right. remove them. don't worry, there is a plate on the bottom. the bolts are attached to the bottom plate. they will not fall out and unless you jack the car up two feet, the bolts won't move. now put the FSTB over the bolts, and reinstall the nuts. Don't forget the covers. Make them very tight. Best mod for this car IMHO. helps tremendously with torque steer.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
umnitza
Sep 1, 2015 01:03 PM
ffcbairn
Aug 16, 2015 09:29 PM
