help with 02 sensor code p2a00
Old Oct 8, 2013 | 11:04 PM
richyung's Avatar
I have a 2006 nissan maxima with the service engine light on with the code p2a00 . I ordered a new sensor from rock auto and got it installed. After i drove for about 20 miles code came back on again. Did Anyone experienced this ? if so how did u get rid of the code
Old Oct 9, 2013 | 03:55 AM
Terrentius's Avatar
Read this web page - http://engine-codes.com/p2a00_nissan.html
At the end of the day, stuff like this can be quite frustrating, for there is no smoking gun, per say. You can chuck parts at it all day and still not correct the issue. And that is very expensive.
So, you gotta be deductive and work through the problem. If you take it to the shop, time is money for them, so they're gonna roll the dice and chucks parts at it until they find it. You, on the other hand, cost nothing, so I suggest you learn about this issue and figure out it out.
Old Oct 9, 2013 | 12:58 PM
po8pimp's Avatar
Check your gas cap is on right and tight. Go reset the codes and see if it comes back. I usually make sure I get two clicks. Overkill, but better to keep from getting ridiculous codes. Check for any intake air leaks.
Old Oct 11, 2013 | 09:14 AM
richyung's Avatar
Gas cap is tight and i used the obII sensor to reset it and code still pops up anyone here knows how to get rid of this code
Old Oct 17, 2013 | 03:32 PM
naijaboy's Avatar
Exhaust leak somewhere close to the o2 sensor
msellas
Sep 23, 2015 09:16 PM
homeofbacon
Sep 23, 2015 07:17 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
