05 maxima running rough..
Old Dec 4, 2013 | 09:46 PM
84johnv's Avatar
when accelerate the whole car start to shake. Car has 160000km on engine. recently changed all six spark plugs and three coils in the back. still have the same problem. motor also has a weird rhythm "shaking" . Don't know what's wrong with it please help. any advise would help. thank you
Old Dec 4, 2013 | 11:09 PM
po8pimp's Avatar
Need more info than the car is shaking. Do you have a check engine light on? Can you post a video? Does this happen when the car is idle? Does it happen when the car is parked with the gas pedal pressed? Did this occur prior to spark plug and coil pack replacement? What else have you done to remedy this particular problem? What other things have you done to the car since this started to include gas type, tire change, brakes, etc. No matter how small you might think it is, you should post it.
Ohh and welcome to the org.
Old Dec 15, 2013 | 01:28 AM
84johnv's Avatar
Problem fixed.. Found out cylinder 1 has a misfire because the injector was clogged. So I took it out and serviced it.. Now the maxima is running at 100% again.. Thanks for the help appreciated
LilVito
Oct 25, 2019 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
acw
Aug 13, 2015 12:50 AM
jholley
Aug 11, 2015 09:38 AM
