Tap noise coming from engine / possible lifter problem?
Old Dec 18, 2013 | 10:42 AM
Doms6thgenmax's Avatar
When I start my 2004 max with 109,xxx miles cold , I hear a faint tapping noise coming from the top of the engine , this happend before and I changed my oil and it stopped . Now it's doing it again. Could it be a lifter ? And is it easy to fix or should I take it to a shop
Old Dec 23, 2013 | 09:41 AM
jasoneon's Avatar
Try changing the oil again. Good chance it's coming from the timing chain area which is pretty common for making some clatter noise (especially on start up).
Old Dec 24, 2013 | 12:22 PM
KevMaster's Avatar
Try adding 1 can of liqui moly to your oil and observe the results after 200 miles driven.
Old Dec 24, 2013 | 12:24 PM
chrome91's Avatar
could be a bit of piston slap or a lifter. if it only happens when its cold and then goes away, i wouldnt worry about it unless the noise becomes constant
Old Dec 28, 2013 | 06:54 PM
twentyeggs's Avatar
It is your timing chain, it will only get worse with time
Hondarydr
Dec 30, 2024 06:15 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
