P0420 and O2 Sensor readings
So wife reported SES on my 04 maxima. Scanned the code and there it is P0420. I am like no dyamn don't need catalytic converter repair right now. I then thought lets read all O2 sensor readings.
Car is in park mode. RPM = 1500
Here are the sensor behaviors:
Bank 1 Sensor 1 - switch fine between 0.2x to 0.8x Volts
Bank 1 Sensor 2 - switch fine between 0.2x to 0.8x Volts
Bank 2 Sensor 1 - Always stays at 0.6x or 0.7x Volts
Bank 2 Sensor 2 - switch fine between 0.2x to 0.8x Volts
Does this Bank 2 Sensor 1 appears to be OK? Does this bank 2 sensor 1 is throwing P0420 code?
That's strange because the sensor is at bank 2 while P0420 is belongs to Bank 1 catalytic converted.
Has anyone seen something like this? can an expert chime in?
Edit:
Here is the scanner screen capture.
Edit:
Today I drove the car to record O2 sensors behavior and here is what I noticed.
Here is graph I had set to observe:
|Bank1 Sensor1 | Bank1 Sensor2 |
|Bank2 Sensor1 | Bank2 Sensor2 |
Bank 1 Sensor 1 - stayed at 0.3x volts (except when at full stop it spikes to > 0.8x/1.2x volts) while Bank 1 Sensor 2 was switching fine between 0.2x to 0.8x volts.
Bank 2 Sensor 1 - stayed at 0.6x volts (except when at full stop it spikes to > 0.8x/1.2x volts) while Bank 2 Sensor 2 was switching fine between 0.2x to 0.8x volts.
Bank 1 Sensor 1 and Bank 2 sensor 1 were following each other.
Bank 1 Sensor 2 and Bank 2 Sensor 2 were following each other.
I am not sure how O2 sensor works and switches but posting this here anyway that might help someone.
All I am trying to see if it's an o2 sensor before worry about catalytic converter.
At the end a good repair shop can diagnose this better.
Bank 1 cats are very common. In all my time at Nissan, I've done maybe 1 Bank 2 cat and many Bank 1 cats. If I had to guess, I'd say the Bank1 cat gets a bit too hot due to it's location. The Bank 2 cat has good airflow around it due it it's location in front of the motor.
Voltage is important, but the frequency is what needs to be monitored. Consult 2 has a scope feature. Also, I'd monitor your bank 1 and 2 Alphas. If the Alphas are normal, it's almost certainly the cat.
As far as alphas in terms I understand the differences of switching patterns, the upstream sensors on both banks alphas are sync with each other with kind of jitter pattern except for the voltage level. B1 S1 stays at 0.3x volts and B2 S1 stays at 0.6x volts. Both do now show any swathing patterns except on full stop I can see both upstream sensors on bank 1 and bank 2 spikes to 1.x volts at the same time and then goes back to 0.3x volts for B1 S1 and 0.6x volts for B2 S1 and stays there.
Regarding to downstream sensors on both banks, the alphas are not syncing with each other all the time. I can see difference between both banks downstream sensors switching patterns. B1 S2 seems to producing uniform swathing pattern. B2 S2 kind of follow B1 S2 swathing patterns but not syncing completely. There are differences in swathing patterns.
Thanks for your help though…
Quick question, if exhaust leaks presents before Y pipe catalytic converter from long time cause pre-cats to gives-up considering car might have run rich? This is what I understood after speaking with an expert.
Any recommendation? Cattman headers or simply get ebay/magnaflow cat?
I think it's safe, can't be any more harsh than any over the counter fuel system cleaners they sell.
Yep first time I got the low efficiency code that you are getting I did it and it cleared up immediately. I then did it a few months later as a precaution. Then didn't do it for awhile and code came back this past October. Put a gallon in and it fixed it again.
I think you should. Scotty Kilmer suggests a tank that is just a little under half but I let my tank run almost out. I put one gallon pure Lacquer thinner and drive on highway at 70MPH for at least 100 miles. Works like a charm.
I might dump lacquer thinner and burn the hell out of it until tank is empty (I mean until tank empty indicator turns on) then fill 3-4 gallon gas and burn that out as well and then fill the tank full to avoid excessive lacquer thinner resides in tank.
If it clears up code then I might buy some extra time to save-up and buy new cats. If it never come back then that's my luck. If it does not fix anything then I will have to slide plastic and pay off slowly. If it damage anything then I know I will be responsible.
What brand and where did you buy lacquer thinner from?
At this point I have no clue if rear cat is just clogged-up or melted/damaged. Car is still running fine and not losing any power. No metal rattling noise at start-up telling me cat has not started breaking-up yet.
Driving it daily now. Work commute is short distance so it will take two weeks to get to 1/4 tank. Not in hurry to burn gas elsewhere to get to 1/4 tank. Meanwhile looking at magnaflow at the end to replace if nothing helps. No SES as of now and hope to see one before I burn paint thinner.
Has anyone else ran thinner before?
NIKV69 claimed he did. I am saying i'll do it soon but that may change.
Not much to it. If you get that code (Cat efficiency below threshold) go buy a gallon. Wait till your tank is 1/4 full, get a funnel and put it in. Drive 100 miles all highway speed. Very simple.
If cat us burnt/melted, no thinner is going to help. If cat is clogged-up (sea foam could be one reason) then thinner might clean-up cat.
I wanted to add my experience. Having issues I found the lacquer thinner trick, but could not find someone who posted experience miles after the fact.
I have a 2003 with 170,000 miles on it. I have codes for rear/downstream O2 sensors on and off for a year or so. Then I got 0420 as well. Since the car tends to drink a little oil I figured the cat may be clogged and the lacquer thinner might work.
I put the gallon of lacquer thinner into half a tank and at first put a stick on the accelerator to get RPM's up to 2500. Within minutes the catalytic convertor began to smoke slightly. This resolved shortly.
After 20 min I drove the car for about 100 miles. No problems with acceleration or Performance noted. I ran the tank down and filled it up, cleared the codes and waited.
No codes for 500 miles. Then I got the same ear/downstream O2 sensor codes I had been getting. I then changed the sensors figuring 10 years was a good run.
Since then (another 250 miles) no codes whatsoever. No noticeable difference in performance. It certainly did not cure my O2 sensors, but may have helped the catalytic convertor.
Before dumping lacquer thinner I had two P0420 codes.
1. Pending P0420
2. Stored P0420
Dumped lacquer thinner and drove 100 miles until empty gas light came on. Refilled gas just enough to drive 100 miles back until empty gas light came on.
Later filled full gas tank and scanned codes again...
1. No Pending code, cool !!!
2. Stored P0420
Cleared the stored P0420 and I will report back if I get P0420 code again.
$20 lacquer thinner
$25 gas to drive forth and back
Worth a shot.
1. Pending P0420
2. Stored P0420
2. Stored P0420
$20 lacquer thinner
Worth a shot.
1. Pending P0420
2. Stored P0420
2. Stored P0420
$20 lacquer thinner
Worth a shot.
1. Pending P0420
2. Stored P0420
2. Stored P0420
$20 lacquer thinner
Worth a shot.
Thanks NIKV69
Its been only 70 miles driven after burning lacquer thinner so it will be interesting to find how long car stay out of P0420 code. Car indeed gained pretty good response. Must be clogged cats got cleared
Do it again whether you have the code or not. I do it every 4 months or so.
Went to dealer last night and they offered 2014 rogue basic model for $19k minus trade in for maxima (I am sure they will low ball) on spot if I go though finance with them. Damn if it wasn't for maxima then I might have traded in on the spot
Yes magnaflow went down with quality and uses low grade material now days thats all the information I gathered from online but I can't say this for sure.
Also I do not require to check emission every year. The only reason I am replacing cat it to avoid catastrophic engine failure if honey comb get sucked back in engine.
The other alternative is to hollow out cat and install back again. However I hate the idea of back pressure will going to be different for front and rear cat unless I hollow out the front one as well for no reason.
I will update ya how this go.....
It's strange after turning SES off it comes back exactly after little over 100 miles. It happened 4 times so far. May be this is normal for car to throw P0420 code.
Getting replaced cat this Saturday. Mine was not clogged but damaged or burnt/melted cat I guess.
Received the Magnaflow. However I am not too impressed with the quality. I was unable to find the close-up images for magnaflow rear cat converter so I gambled. Here are some snaps to look at it close. Its tiny than what I was thinking. I tool pictures with 11 x 8.5 standard size paper to compare the size of this cat. Also the honeycomb material is not uniform and kind of already broke off as you can see in picture 4 and 5. Is this normal or should this cat go back to store again? I hardly deal with exhaust so I am not sure this is normal looking cat inside. Any feedback will be appreciated.
Exhaust leak. That was diagnosed by shop.
I used to get P0420 and I was clearing that code OFF however after 100 miles it was coming back. Burnt lacquer thinner and SES came back after 100 miles again. So I bought the cat to replace and I was waiting for SES to show up again.
This time around after 130 miles SES did not turn ON. Regardless I went to shop to replace the cat. They jacked up the car and diagnosed exhaust leak at flex joint (that was repaired else where long ago).
Its kind of surprised because I did not hear exhaust leak while driving. Probably a small crack to notice. Shop said they are confident the leak was throwing P0420 so they advised to wait and watch.
Paid $40 to fix exhaust leak and drove another 30 miles and still no SES light. Car also ran little smooth after shop fixed the leak so that tells me leak was there but it just I didn't knew about it and I thought the noise while driving the car is normal due to age of the car.
Interesting.......I am still holding on to the cat I bought just in case SES light comes back on again.
I will keep update ya'll on progress.
