No pedal response, TCS and SLIP light are on
Old Dec 27, 2013 | 05:58 PM
GaMaxinKy's Avatar
I have my TCS light and SLIP lights are on and no pedal response, problem has been intermittent and Pedal has been replaced twice still seeing issue, HELP...
Old Dec 27, 2013 | 06:14 PM
theblackone3.5's Avatar
check the fuse first.
Old Dec 30, 2013 | 06:40 AM
cman01's Avatar
This happened to me out of the blue on the highway a few months ago. Stepped on it to merge and then the slip light and TCS light came on and I got no throttle response. Luckily I was able to pull over to the shoulder safely. I was close to my exit and dealership, still had to get towed. It ended up being the potentiometer inside the throttle body went bad.
Old Dec 30, 2013 | 07:36 AM
MoncefA33's Avatar
If it's not the gas pedal then the throttle body is most likely your culprit.
Old Jan 17, 2014 | 01:33 PM
sr collector 20's Avatar
Mine did the same thing and no check engine light! I had to turn car off and on like ten before the check engine came on and it was the crank sensor
mvm062
Nov 30, 2020 09:00 AM
vingodine
45
May 21, 2016 12:46 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
yat70458
Aug 3, 2015 01:16 PM
