Cylinder 1 missfire
Cylinder 1 missfire
I have a cylinder #1 missfire I cant get rid of. Engine runs smooth most of the time and the only way I can feel it is to power brake it at about 1/4 throttle. Have replaced sparkplugs coil injector and intake manifold gasket. What else could be the problem. It is a 2004 maxima and that is the only way I can get it to miss and not every time.
Failing o2 sensor? Check Engine Light on? I was having random misfires. Car would pull fine some days and miss on others. Slowly begun getting worse. Eventually the car threw check engine codes for o2 sensor bank 1 and random misfire. Changed the o2 sensor and performed the Air/Fuel Ratior relearning procedure and car has been fine since.
I changed crank sensor and cam sensor on rear bank. Does front bank have cam sensor too?. Have not changed O2 sensor. Which one should I change or all? How many does it have? I used OEM coil and sparkplugs
Go with camshaft sensor first which is easy to replace but will cost under $100 for sensor. There are 4 O2 sensors and if you have a good scanner then it will be easy to find out if one of the sensor is lazy or not working.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
