6th engine swap
Old Feb 17, 2014 | 01:52 PM
Chris Alexander's Avatar
6th engine swap
Would it be possible to swap out the VQ 3.5 from an 04-06 Max with the VQ 3.5 303HP from a 2010 Infiniti M? The M's transmission is 7 Speed AT. Imagine if Nissan had taken the 6.5 gen and given it a 300HP 7speed AT as a mid cycle update the 6th gen would be in a good place with that even to this day.
Here are the Specs on the M
3,498 cc 3.5 liters V 6 front engine with 95.5 mm bore, 81.4 mm stroke, 10.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder VQ35HR
The Max Specs
3,498 cc 3.5 liters V 6 front engine with 95.5 mm bore, 81.4 mm stroke, 10.3 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder VQ35
Old Feb 17, 2014 | 05:47 PM
po8pimp's Avatar
Umm I believe the M series are all rear wheel drive. Wait for the 8th gen and swap that motor in.
Old Feb 17, 2014 | 05:52 PM
po8pimp For some reason I always thought the 2nd gen M and the 6gen Max were the same car just different names. The 8th gen Maxima that engine probably wont be compatible for a 6th gen for alot of reasons.
Old Feb 18, 2014 | 02:01 PM
nsnrider's Avatar
that won't work due to rear wheel/ all wheel drive transmission.
Or should I say, it could work but would be very expensive.
Old Feb 19, 2014 | 06:19 AM
Maximam's Avatar
Ya you would have a heck of a time with those throttle bodies in FWD.
Old Feb 19, 2014 | 01:47 PM
justin2386's Avatar
swap on a 6th gen intake/tb? would that work? or perhaps a kinetix racing one to improve the flow? it will work if FWD and RWD blocks are cast the same, then its just a matter of swapping FWD stuff onto the RWD motor (accessories, flywheel, motor mounts, etc
Old Feb 19, 2014 | 02:25 PM
NmexMAX's Avatar
dot dot dot ...
6th gen VQ35DE
M Series, VQ35HR
RWD vs FWD info, mostly on the DE series of both RWD & FWD: http://forums.maxima.org/all-motor/5...s-lengthy.html
Dual MAF/TB > than our single inlet IM's any day, and that also means the Kinetix. Also, HR has CVTC on both I & E cams. With that last part said, it would turn into a bear to account for those items and get the most out of it toe ven think about making it worthwhile.
The best thing for us at the current moment is to swap in a 7th gen engine. Far easier, and very beneficial (300+ whp with typical bolt ons and some tuning).
Old Feb 19, 2014 | 02:44 PM
justin2386's Avatar
for a 7th gen swap, anything else have to be done besides swapping motor? do you have to swap or tune the 6th gen ECU? my car is an 06 6spd, would i just swap over flywheel/clutch and obvious things and be good to go?
Old Feb 20, 2014 | 07:19 AM
po8pimp's Avatar
You will almost always need an ECU when swapping engines. I recommend finding a shop near you or a friend who has done this before. Figuring it out from scratch is not impossible, just gonna be painful lessons learned that could be avoided. Mounting and trans matchup are the most important. Most other stuff can either be rewired, or relocated to fit. Good luck and if you do manage this, I recommend doing a complete writeup for others. Also might want to post this in the Tech section http://forums.maxima.org/all-motor-61/ . Here is some good reading on the FWD vs RWD differences in the VQ35DE motor to give you an idea of what you would be looking at for a swap. http://forums.maxima.org/all-motor/5...s-lengthy.html
Old Feb 21, 2014 | 11:51 AM
NmexMAX's Avatar
dot dot dot ...
It can't be all that different for a 6th gen.
http://forums.maxima.org/all-motor/6...vq35-info.html
Old Feb 23, 2014 | 11:32 PM
4drsportscarenthusiest's Avatar
hey fellas! so im doing an engine swap on my 2000 max. but ive ran into some problems! my max is a 5 speed. and the engine I got came from a 2000 automatic and some things arnt lining up. like the manifold and the flywheel and some mounts.. anyone got anything for me
Old Feb 23, 2014 | 11:41 PM
maxima.713's Avatar
I dont know how you are having those problems when it doesn't matter if the motor came out of a auto maxima.
Old Feb 23, 2014 | 11:53 PM
I don't know either. I called the dealership since their "experts" and they said that the only thing that should be changed is the pressure plate. but the guy I have installing it is having other issues
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
I<3 A32's
Sep 10, 2015 11:07 AM
