Transmission oil change
Old Mar 16, 2014 | 01:40 AM
thewomble's Avatar
Maxima 2004 62,000km.
Want to do a AUTO transmission oil change.
First option .. drop pan, new filter and gasket...OR
Second option .. as above but with a flush as well.
What do members recommend.
THANKS.
Old Mar 16, 2014 | 05:58 AM
NismoMax80's Avatar
SuPeRmOd
100s of posts state drain and fill. will be hard for you to find someone that can or is willing to flush this car. use only Nissan Kmatic
Old Mar 16, 2014 | 06:00 AM
NismoMax80's Avatar
SuPeRmOd
no need to replace filter. (is there one?) drop pan if you want but not necessary.
Old Mar 16, 2014 | 07:01 AM
Kryogen's Avatar
are you kidding me?
might want to read one of the 20 gazillion threads about it?
everything has been said sorry. read a bit.
Old Mar 17, 2014 | 12:09 AM
thewomble's Avatar
Originally Posted by Kryogen
are you kidding me?
If I had found the answer in a thread I would not have asked.
Old Mar 17, 2014 | 12:12 AM
thewomble's Avatar
Looked but did not find an answer.
Thanks for your answers.
My local quoted for pan removal, filter change so I? am assuming it does have a filter.
Will find out yes or no when I get the job done.
Forgot to say it does not have CVT transmission.
Old Mar 17, 2014 | 05:10 AM
NIKV69's Avatar
No need to drop pan. Just drain and measure how much comes out and put exact same amount back. Only use Nissan K matic.
Old Mar 17, 2014 | 06:17 AM
thewomble's Avatar
Thanks for the helpful answer.
Will be doing the oil change next week after getting some Nissan Kmatic oil.
Old Mar 17, 2014 | 10:23 AM
NIKV69's Avatar
Kewl keep us posted.
Old Mar 17, 2014 | 01:11 PM
Quickywd01's Avatar
I'd put amsoil synthetic atf in there if I were you.
Old Mar 17, 2014 | 06:10 PM
Kryogen's Avatar
no, use only nissan k matic or you are asking for trouble.
the transmission was built to run on k matic. use k matic.
on the 5 speed (with shiftronic) there is no pan, and there is no filter, AND you cannot flush it, because there are no oil lines going out.
(unless you have the 4at? I dont know about this one)
you can do 3x drain and fill, driving in between a few minutes in all gears.
then
as long as you drain and fill once a year, you are never going to get trouble with that fluid.
DO NOT use anything else than k matic, you will be sorry when your transmission screws up.
I do a drain and fill every spring when I change my oil. solved all my issues, never had any other transmission roughness, been 130 000km since.
Old Mar 20, 2014 | 12:07 AM
jmatusko's Avatar
THANKS.
Make sure its Nissan matic K. You can use Valvoline synthetic import. But I recommend buying directly from Nissan. It might be a little more money but its better for the tranny. You need a 10mm allen wrench to undo the plug on the front of the tranny- drivers side. Make sure to put the exact amount that came out and good luck!
sctludwig
Sep 1, 2022 01:32 PM
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
20
Sep 17, 2015 08:12 PM
pjgreek
Sep 9, 2015 09:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
