2004 Nissan Maxima 6 speed p0300 trouble
Old Apr 22, 2014 | 06:02 PM
rizohalim's Avatar
Hi guys, I have my 04 maxima 6 speed with only 99,000 miles. Its getting a p0300 code, the car bogs for 10 sec than idles fine for 2 min. than it bogs again for 10 sec than idles fine for 2 min. I driver this car everyday, it has full power and everything is perfect, it just bogs a lot. Changed all coils, all plugs, maf sensor, cam sensor, crank sensor, timing chain tensioner, converter, ypipe and catback. Please help if you can thanks
Old Apr 26, 2014 | 06:24 PM
dfj240's Avatar
Check the throttle unit. It houses the IACV and TPS, which can cause the P0300 code. Sounds like you've covered every other base though. I have gone through the same headache with my 02 6-Speed. Mine ended up being clogged precats, but you say you've already replaced those. I hope that can help point you in the right direction at least.
Old May 11, 2014 | 07:01 AM
rizohalim's Avatar
maxima
Hi and thank you for your response. I only changed bank 1 pre cat which is the rear one. Do you think it's the front pre cat. thanks
Old May 13, 2014 | 02:10 AM
dfj240's Avatar
It's possible, but it would behoove you to test and therefore be sure first. If you have a vacuum gauge, let me know and I'll run you through a very simple test procedure to see if there's a clog or not.
xUNIxPanther
Aug 27, 2015 10:09 PM
09maxshawn11
Aug 14, 2015 10:07 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
