Transmission issues
Old May 12, 2014 | 10:17 PM
go4itmax's Avatar
Transmission issues
strted a couple days ago. Transmission will not ship until higher gear no passing gear, I get a big bang in Reverse. Can someone help me figure this out.
Thanks for the help.
JR
Old May 13, 2014 | 01:24 AM
230's Avatar
230
JR
The first sticky on top of 6th gen max forum will help you out.
you should search this forum for transmission solenoids.
many people try a quick fix by draining the transmission fluid and then refilling the transmission fluid (Not a FLush). Use Matic-K fluid from dealership.
If your transmission is in real bad shape you will probably need a valve body rebuild (solenoid upgrade) or new valve body assembly.
I hope this helps some.
Old May 14, 2014 | 07:22 AM
cornfedmax's Avatar
Do you know for sure if you have all gears engaging? Also. If it's slamming hard in reverse then iwould ddefinitely drop the tyranny pan and check your solenoids. This is only if you are positive that you have every gear though. If you are missing a gear like first or top gear, you may have some more serious issues. I just replaced my 4 speed a couple months ago and if you have a pretty decent mechanical hand it's really not too difficult to swap it out with a remanned or lower milage tranny, that is of course assuming you have a hoist. If not tractor jack stands will work pretty good to.
sctludwig
Sep 1, 2022 01:32 PM
The Wizard
24
Oct 1, 2015 08:47 PM
videomano
Sep 8, 2015 03:28 PM
dcardello
Sep 3, 2015 11:44 PM
