Is there any issue with driving on a P0302 code
Old Jun 15, 2014 | 10:04 AM
dtahsee's Avatar
The "Service Engine Soon" light on my 2008 maxima came on the other day and when I had the codes pulled at Autozone, it was a P0302 (Number 2 cylinder misfire detected). I am hoping to take the car to a mechanic later in the week. What can happen if I continue driving with this code? Will the car stall and leave me stranded somewhere or will it cause irreparable damage to the car? On another note, any ideas on what the issue could be? If I can fix it myself, I'd rather do that. Thanks.
Old Jun 15, 2014 | 11:22 AM
Fakie J Farkerton's Avatar
As long as your check engine light isn't flashing, then you should be ok for a while.
Old Jun 15, 2014 | 05:55 PM
dfj240's Avatar
The issue is likely to be the coil on that cylinder. Easy way to tell is to pull the coil from cylinder 2 and put it on a different cylinder. Ideally, take it and install it somewhere on the front bank(much easier to get to). If the code moves to the cylinder you changed it to, then you know it's the coil. Replace the coil with an OEM coil, and job done.
Old Jun 16, 2014 | 04:50 AM
dtahsee's Avatar
Thanks guys. I decided to take the car to the mechanic this morning but the SES light is now off. I drove the car and it wont come back on. My assumption is that the mechanic will not be able to pull a code if the light is not on and if they do try to diagnose based on P0302, things may not malfunction.
Old Jun 16, 2014 | 10:16 AM
tosheto's Avatar
That means that most likely coil 2 is slowly going out and sometimes it works, sometimes it does not. You will need a new coil in the future.
Old Jun 16, 2014 | 12:18 PM
SSandMaxima's Avatar
This. I had one that threw a code (off and on) for a year !
Old Jun 17, 2014 | 01:39 PM
myownworld's Avatar
The danger of running with a misfiring coil is unburned fuel gets dumped into your precats and begins to foul them as well.
kjlouis
Nov 24, 2018 06:09 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Slamrod
Sep 3, 2015 07:38 PM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
