Leaking coolant heater core
Old Jun 22, 2014 | 09:14 AM
dannydifalco's Avatar
I have a 07 altima (not a maxima) 4 door with about 105k its the 2.5l. It has just started loosing coolant. The radiator would run dry and the overflow would empty itself. I have check everywhere under car for leaks. Nothing. Top hose hot bottom one colder. I have flow through both so its deff not the thermostat. I recently started to smell coolant inside the car and now have coolant on driver side floor by pedals. So I'm convinced its the heater core. I also don't get good heat at idle but a lot when revving or driving. What are my options? Can i bypass the heater core? Could the heater core be clogged? Will a flush unclog it? Whats the cost to tear the dash down and replace the heater core?
Old Jun 22, 2014 | 11:15 AM
Kryogen's Avatar
the more I read this forum, the worse it's getting.
dude, obviously you have no clue, please, call nissan and have it fixed....I mean, what else can you do.
Old Jun 22, 2014 | 11:18 AM
Good idea! What's the point of the forum then? I guess when we all have problems we should all just call nissan. What part of this do I not have a clue about? Please specify.
Old Jun 22, 2014 | 02:20 PM
Kryogen's Avatar
Sorry. You just obviously cannot fix it yourself.
There is nothing we can do to help you with that, you should really have it fixed in a shop.
Old Jun 22, 2014 | 07:54 PM
myownworld's Avatar
Its going to cost approx $600-900 to replace your heater core. Can you bypass it? Sure, if you never want to have heat in your car and never want to sell it later. I cant tell you how much it will cost to bypass it because I have never asked or tried.
Old Jun 22, 2014 | 08:03 PM
chrome91's Avatar
bypassing it is easy, you just have to connect the hoses going to the heater core going at the firewall with a piece of PVC pipe or something and some clamps. heater core started leaking on my Hilux and i bypassed it because aint nobody got time fo dat
labour to replace the HC in a shop is a few hundred-ish. its all labour costs for tearing down the entire dash
Old Jun 22, 2014 | 09:09 PM
Just bypassed it. Bought $3 line at autozone. Took 5 mins problem temporarily fixed. Bringing to nissan tomorrow to see if my warranties will cover it or get a price quote.
Old Jun 23, 2014 | 05:20 AM
MadMax07SL's Avatar
I've never done a Nissan, took out the evaporator on a Neon (essentially the same job as heater core, since both are in the same dash box) I'll tell you, at the time I needed the money so I did it myself, took 3 days and the car was out of commission until it was done. THE longest job I've ever done on a car...i'll never do one myself again!
Old Jun 23, 2014 | 05:58 AM
Kryogen's Avatar
it's such a pain to get access to the evap on the max, it's crazy.
I tried to gain access to clean it, because it's full of mold, and I just gave up.
You would really have to tear down a LOT of stuff to get there.
Imo will cost above 1000. I would say 1400?
Old Jun 23, 2014 | 03:59 PM
DennisMik's Avatar
FYI the evaporator core and the heater core are not in the same box on the Maxima. The evaporator core is A LOT easier than the heater core.
Don't know if the Altima is the same as the Maxima.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
