bad timing or something wrost
Old Nov 10, 2014 | 05:10 PM
kingtee's Avatar
i have a 2004 nissan maxima that i ran hot and blew the head gasket on and the lifter got stuck i brought new heads and got them put on but i think my timing been set wrong because when you try to start the car it cranks but kills right away you have to keep pressing the gas to keep it running and it has a random misfire and its backfiring and when i backfire even if im pressting the gas it dies so could the be a timing problem or worst and i have a lifter tap but im guessing the lifters are not primed up yet
Old Nov 11, 2014 | 08:15 AM
DennisMik's Avatar
Go back and check all the timing alignment marks for the timing chain.
The lifter tapping is a mechanical adjustment using shims. The engine does not have lifters.
Old Nov 11, 2014 | 10:06 AM
kingtee's Avatar
Yeah I think the timing is about 180 degrees off because I didn't make sure that the crank was set at top dead center all I did was line the crank and the cams up and put the chain on
And would a rod bearing cause the knocking/tapping noise? Because I noticed when I took the oil pan down I had copper color metal in the pan
Old Nov 12, 2014 | 09:37 PM
DennisMik's Avatar
If you had the timing 180º off, the engine wouldn't start in any way, shape or form. One tooth off is more likely.
A valve tappet noise and a rod knock are different in sound. A tappet is kinda like a click whereas a rod knock is a deeper, more solid sound. And yes copper type metal could be a rod or main bearing. That is not a good thing to find.
Old Nov 13, 2014 | 04:33 PM
kingtee's Avatar
i think its more than one tooth off because it just spins over i would have to keep pressing the gas while its spinning over just to get it to crank but it dies soon as i stop pressing the gas or it would back fire and shut off and my spark plugs are fouled so yea im pretty sure the timing is off now
with the knocking, the speed of the knocking increases as the rpm raises and its a deeper sounding knock so im pretty sure its rod bearings
but ill tear it down and retime it and change the bearings this weekend
thanks alot for replying to this, ive done a lot of research on my problems after what you had to say
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
May 24, 2019 02:58 PM
kjlouis
Nov 24, 2018 06:09 AM
FlaMark
25
Aug 28, 2015 10:15 AM
doobadoo
Aug 15, 2015 06:43 PM
