Idle Speed
Old Jan 20, 2015 | 11:24 AM
Biscut's Avatar
Idle Speed
I just did an intro post and indicated I do not have any indication of chain tensioner issues. I wanted to ask about idle speed on the Maxima's of our generation. In the very cold temps, 0-10F the idle speed gets up there. Pretty common for a car I know, but seemed a little high.
Normal for the 3.5??
Old Jan 27, 2015 | 02:28 PM
NmexMAX's Avatar
dot dot dot ...
Normal for all modern day cars in that when cold, the idle is a bit higher in an attempt to reduce emissions in that the higher the idle, the faster the pre-cats are warmed up, which then allow them(pre-cats) to work more efficiently at removing uglies from the exhaust at a faster rate until the vehicle comes to operating temperature.
What does it regulate at when the car is at operating temp?
MT: 625±50 RPM
4AT: 700±50 RPM
5AT: 675±50 RPM
In P or N w/ AC on 825 or more.
Old Jan 29, 2015 | 08:07 AM
Biscut's Avatar
Thanks for the reply. It was new to me and I thought it a bit high. Now I see it's consistent and as soon as you begin to drive it all settles down.
Warm in P it's about 850RPM All good!
Old Jan 29, 2015 | 01:38 PM
nupe84's Avatar
There is supposed to be a way to reset it in case it's running too high but I haven't been successful at doing it. Mine is running around 1000 RPM once it's warm.
Old Jan 29, 2015 | 03:01 PM
NmexMAX's Avatar
dot dot dot ...
If you have access to a Cipher/UpRev tuner, you can adjust it somewhere in the +/- 50 RPM range. Seems as if you may need to do the IACV re-learn procedure. That’s a little high though, mine did that and had to do that(IACV/Throttle relearn procedure) a few times and it went back to normal.
The Cipher is a nice tool and it will tell you why, should tell you why, your idle is so high.
Old Jan 29, 2015 | 04:24 PM
MyMaxx22's Avatar
idle
I posted something similar to your post, RPM surge no replies.
I did some research of my own, and found Idle re-Learn. I would
Idle between 800 rpm & 1,200 rpm. After doing the re-Learn everything
Went back to normal. Hope you make out!
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
