Starter Issue. what to check ?
Old May 22, 2015 | 10:28 PM
Pnjboyzz's Avatar
Hi Experts ,
thanks for your time and suguestions
lately my 04 maxima hesitate to start. what should i check before i replace the starter
thanks
Old May 22, 2015 | 10:38 PM
chrome91's Avatar
so the starters not turning at all? check the battery connections, battery cables, starter wiring, and starter cables. if all is good, you can remove the starter and hook it up to a booster pack to see if it turns
try starting it in neutral as well if its an automatic
Old May 22, 2015 | 10:48 PM
Pnjboyzz's Avatar
it does start but it take atleast 15 seconds. it kick several times
what is a booster pack ? and how to use it ?
where is the starter located on 04 Maxima ?
Old May 22, 2015 | 11:41 PM
chrome91's Avatar
so when it kicks it quits cranking? if it cranks for 15 seconds but wont start, thats not a starter problem. thats something else. if it cranks for a few seconds then the starter quits cranking, that can be multiple things. hold-in of the solenoid failing, poor connection, etc
booster pack is a battery jumper like jump cables kinda, you can remove the starter and hook up a battery pack to the solenoid to see if the starter gear is turning or not. the starter will be on the transmission near the bellhousing, i believe you can see it from up top
Old May 23, 2015 | 12:21 AM
Pnjboyzz's Avatar
what is " hold-in of the solenoid failing" ?
poor connection ? is it a battery ?
what else can be check to fix this starter cranking issue ?
thanks
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
Djsmaxima
Sep 14, 2015 11:58 PM
Bonka
Sep 14, 2015 11:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
