2007 Nissan Maxima CVT Indicator Light
Old Aug 18, 2015 | 06:23 PM
trasmadean's Avatar
Hello, I have a 2007 Maxima 3.5 SE. It has the CVT Transmission. I knoiw it has the CVT by the handling of the car also It is labeled CVT unbder the hood and the dip stick has CVT and to use NS-2 Nissan fluid. My issue is I do not see a CVT indicator light at any time when the ignition is on or at start up. From the manual my understanding is the letters "CVT" should light up for a couple seconds after the the ignition ois in the on position. Does this car have a CVT indicator Light? Is it something other than the letters "CVT"? Thanks for any help.
Old Nov 11, 2015 | 12:55 PM
trasmadean's Avatar
Problem solved. Cluster is bad. Got a used cluster on ebay now my CVT light comes on briefly at start up like it should. I also discovered that my ABS, TCS off and slip lights work. They work so good they don't shut off. Ha Ha! Now to tackle this problem.
Old Jan 19, 2018 | 01:48 PM
CHEF KOCH's Avatar
I just finished praising the CVT then I saw your thread title... :S Glad it worked out good for you. Awesome cars
Old Jan 20, 2018 | 05:05 AM
trasmadean's Avatar
Update: The problem was the used car lot I bought it from put black tape over the abs lights to hide an abs issue. They covered up the CVT in the process. CVT is fine. Took me several weeks to fix the abs issue (I have another post about that).
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
kjm900r
Aug 5, 2015 07:14 AM
