P0726 Check Engine Light
Old Oct 5, 2015 | 03:38 PM
osisray's Avatar
I had the check engine light come on. Everything appears fine. The car starts like it did before on the first crank, the transmission shifts fine.
I took it to Advance, the guy hooked up the OBD11 and read this code
P0726 - Trans Engine Speed Sensor
What could be causing this ?
- Crankshaft Position sensor bad ?
- Something else ?
Like I said, everything looks fine except check engine light stays on.
Old Dec 9, 2015 | 11:05 AM
Jimbeezeetheman's Avatar
I have the same code
- Something else ?
I have the same code that popped up. Did you get it fixed? I think it jus means you need to change out the sensor, it's not a mechanical issue.
tgreen
Oct 18, 2015 06:18 PM
fastcarny
Oct 6, 2015 10:42 AM
iamute
Sep 20, 2015 05:22 PM
Steven Orozco
Sep 12, 2015 10:41 PM
lux97Max
Sep 11, 2015 01:12 PM
