Window won't go up
Old Dec 26, 2015 | 01:42 PM
Pnjboyzz's Avatar
Window won't go up
Hi guys,
My window sometimes go up and some times don't.
Sometimes I hear the motor pushing the window hard then stop moving up.
Any idea which part might going defective .
Old Dec 26, 2015 | 06:16 PM
DennisMik's Avatar
Maybe the glass is binding in the track. Maybe the glass or the tracks have come loose so that the glass can tilt and bind.
You will have to take the door panel off so that you can look inside to check things.
Old Dec 28, 2015 | 11:31 AM
Pnjboyzz's Avatar
thanks
but when i try pulling the window by my hands, it does close the window.
i do not think its the track.
could it be possible the motor is going weak ?
Old Dec 29, 2015 | 01:15 PM
DennisMik's Avatar
It is possible that the motor has gone bad. Maybe the brushes in the motor are almost worn out and making intermittent contact.
It's also possible that the vulcanized rubber sections of the big final drive gear in the motor have separated. But you should hear the motor running without the window moving.
Old Dec 30, 2015 | 07:35 PM
Pnjboyzz's Avatar
thanks for your support.
it turns out to be motor was weak.
installed reman motor and it works perfect.
James_EastTX
36
Jan 28, 2023 03:54 PM
Derrick2k2SE
Dec 30, 2015 11:45 AM
Quantumxl
Dec 26, 2015 11:26 AM
MaxRPM6
Dec 26, 2015 11:11 AM
mrdigray
Dec 24, 2015 04:05 PM
