cleared p0455 now have p0300
Old Jan 15, 2016 | 04:10 AM
Jayfella973's Avatar
Hello all had a code for p0455 which was a large leak in the evap system I replaced the vapor canister purge valve let the car run for a bit I read the code again and now it's p0300 random multiple misfire and the evap code was not there I do have a REALLY bad exhaust leak where pipe meets the muffler is absolutely disconnected rusted after years and eventually cracked and broke I am waiting on a new full exhaust until then I was wondering if the broken exhaust would cause the misfire I just feel it's fuel related because of the purge valve I replaced and the misfire code was not there prior
Any insight would be helpful
Old Jan 15, 2016 | 09:24 AM
DeusExMaxima's Avatar
A leaky exhaust can cause the engine to run inefficiently. These sensors and the ECU are so sensitive these days, that if the O2 sensors are operating at 95% efficiency, a code can be triggered. I'd suggest fixing the leak, as you seem to be doing, and then clear the codes and see if any pop up.
maxinout93
42
Dec 7, 2015 07:42 AM
mclasser
Nov 26, 2015 12:06 AM
sanford7575
Nov 17, 2015 12:12 PM
njpunkmusic
Nov 10, 2015 09:29 AM
Dave20
Nov 2, 2015 07:41 PM
