New here, bought new rims that don't fit need help
Old May 13, 2016 | 09:07 AM
Maxima06se's Avatar
Hi guys I bought these 18" rims for my maxima and on the website it said they would be a good fit for my 06 maxima se but when I went to get them installed the lug pattern turned out different it was more spaced out on the rim. According to the site the bolt pattern is the perfect fit etc. I have on stock 18" rims on my car. Got a really good price on them from craigslist and they matched my car. Not sure what the problem is?? http://www.tirerack.com/wheels/Wheel...6&autoModClar= Plz help thanks
Old May 13, 2016 | 11:18 AM
NmexMAX's Avatar
dot dot dot ...
Your bolt pattern is 5x114.3 So the wheel you linked should fit, unless the craigslist seller , you might either be concerned with offset or bore size.
Might be a little more informative.
Old May 13, 2016 | 11:23 AM
Maxima06se's Avatar
Yea the bolt pattern of my car is 5x114.3 which should fit so I don't understand y it's not fitting. Anyhow is there anything I can do to still put them on the car?!
Old May 13, 2016 | 11:26 AM
Maxima06se's Avatar
Old May 13, 2016 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
Are you sure the CL seller knew the exact BP of the car? So what deosn't fit, the bolts don't line up to the bolt holes? Or are they hitting your brakes, or is the hub too large to fit into the center bore of the wheel?
Old May 13, 2016 | 11:39 AM
Maxima06se's Avatar
The bolts aren't lining up to the holes
Old May 13, 2016 | 12:54 PM
NmexMAX's Avatar
dot dot dot ...
Have you tried it? Sometimes it takes me a couple of tried when I'm putting mine back on. Maybe take some measurements off the wheel.
Use the middle one and measure away using the holes specified. 5x4.5".
Old May 13, 2016 | 01:25 PM
Maxima06se's Avatar
Yea thanks just measured it again I'm getting the same measurement which is 4.5" same as stock rims...
Old May 13, 2016 | 01:31 PM
NmexMAX's Avatar
dot dot dot ...
Damn .... that might be why.
Old May 13, 2016 | 01:49 PM
Maxima06se's Avatar
Not sure what u mean...the measurement comes out same for the stock rims and these rims...
Old May 13, 2016 | 02:09 PM
Maxima06se's Avatar
Contacted the CL guy he said he bought it from someone else for the tires didn't even use the rims also said the guy had said the bolt pattern is 5x5
Old May 13, 2016 | 02:30 PM
NmexMAX's Avatar
dot dot dot ...
I meant that might be why they don't fit because the holes are a 1/2" off. Sucks man ... sorry to hear.
Old May 13, 2016 | 03:40 PM
Maxima06se's Avatar
Yea but not sure why the website wasn't accurate as far as the size its really 5x127mm instead of 5x114mm as listed...
mr Jones
May 16, 2016 04:05 PM
Roblee
21
May 11, 2016 05:06 PM
Anovice
May 10, 2016 12:03 PM
STAXiMA
May 7, 2016 01:23 PM
