timing chain replacement
Old 11-10-2016, 12:21 PM
eastsidemoon's Avatar
Has anyone purchased the full timing chain replacement kit for a VQ35DE? If so, from where, what brand, and how much?
eastsidemoon is offline
Old 12-01-2016, 06:36 AM
oldpuck81's Avatar
I see that Autozone and O'Reilly's has several parts to the cam drivetrain package. Otherwise, Nissan would be your main source. Not sure if they also come in a "kit".
oldpuck81 is offline
Old 12-01-2016, 07:49 PM
AscendantMax's Avatar
I wouldn't tackle replacing the timing chain if you're not too mechanically inclined. Why do you want to replace it? But if you're going to tear into the side of the engine, go ahead and replace the tensioners before they give you issues.
AscendantMax is offline
Old 12-02-2016, 07:53 AM
oldpuck81's Avatar
Why not?
Why would you not want to replace the chain? If you got it all open, then replace everything that could possibly wear out going forward. Doing so removes more risk of future failures. The Nissan TSB states to replace the secondary (short) cam drive chains along with the nylon tensioner shoes. Tensioner replacement not required. But if those chains have been riding on the steel tensioner piston, i.e. metal on metal, why would you not put out a few extra dollars and replace them? The main chain usually does not hit metal on metal if the main slack guide and tensioner fail as they typically do. If you have torn this far into an engine, do it right and replace all parts that could pose future risk.
