07 Maxima Hyper Flash Signal
so this just started to happen, when i put my right turn signal, my signal starts to flash insanely. my blinkers are white, then turn amber at night.
can anyone help me with this situation... i read up that ill most likely need to resisters.
It is always a good idea to get the resisters with the LED bulbs. For my car (not a Nissan) I bought from a place that has their ideal tested resistors, that way you're sure the vendor has already tested them together so you're not troubleshooting issues in uncharted waters. They don't cost much, $3-$7 each. You will need one for every single LED turn signal in most situations. The idea is that the LED doesn't put up as much resistance as an incandescent bulb, therefore the sensors/computer detect a false positive for a dead bulb, signaled by the hyper flash. There really is no safe way to hook up one resistor to both turn signals that I can think of.
Here's where I got mine for just the rear lights...
https://www.k5optimastore.com/collec...ant=1087619724
That said, I still don't understand why they can't just build a resistor into the bulb housing...unless it's a heat/life issue for the bulb...still, sometimes installing a resistor takes 5 times longer then what it takes to replace the bulb...depending on how accessible the wiring is. Not to mention you do something wrong, you're going to screw up some wiring...
would you recommend taking the bumper down to put the resistors and to also switch the signal bulbs?
i was quoted a price $120 to change the front signal bulbs to led switching from white to amber, and to also change the resistors.
i am really hoping that they don't have to remove my front bumper to change them.
i installed switchback led for both front turn signals and also installed resistors for each front turn signal. yes, i had to remove the front bumper in order to remove the headlight housings. I bought the led switchbacks and resistors from retrofitsource
