07 Maxima Key Fob
If you don't have the ikey system, this should do it.
1. Unlock all doors and get in car.
2. Close and lock all doors with power door lock switch on driver's door.
3. Insert the ignition key and completely remove it at least 6 times
within 10 seconds. The hazard warning lamps (both turn signals) will
then flash twice and all previous codes will be cleared.
4. Turn ignition key to "ACC" position.
5. Push any button on the new remote control key fob once. At this time,
the car learns the new ID code. The hazard warning lamps (both turn
signals) will then flash twice.
If you are programming just one remote, go to step 10.
If you need to activate additional remote controllers, continue with Step 6.
6. Manually unlock the driver's door only then lock again with door lock
7. Push lock button on the additional remote controller once.
8. Hazard warning lamps (both turn signals) will then flash twice and
additional remote is programmed.
9. For additional remotes, go back to step 6.
10. When done, open the driver's door to exit programming state.
NOTE: A maximum of 4 remotes can be programmed to any ONE car.
NOTE NOTE: In Step 3, use as much of the 10 seconds as you can.
It is possible to go too fast and you will not enter
programming mode.
programming mode.
