speed / transmission / sensor issues
Old Apr 18, 2019 | 06:58 AM
hlautz's Avatar
I have a 2007 Maxima. Recently I have been having issues with what I thought was the CVT transmission. When the motor is cold it runs fine. Once it is up to temp the rpm will jump, but the speed will slowly decline. I have changed the Transmission Speed sensor and the Mass Airflow sensor. My speedometer is approx. 5-7 mph higher than the actual speed so I thought it may have something to do with that, but I am unsure. Has anyone ever had this issue? Any help is appreciated. The car goes into a sort of limp mode once the motor has reached temp.
Old Apr 18, 2019 | 08:30 AM
6genRAXXIMA's Avatar
I recently had a similar issue. I would accelerate to 40-50, then when I'd brake, my ABS would go off and I wouldn't be able to accelerate whatsoever. Turned out to be a bad Wheel Speed Sensor (right rear). Apparently, it's a common issue, and a bulletin was sent out by Nissan once the problem surfaced, but none of the previous owners or shops saw it, or they didn't do anything about it. Maybe have a shop run a diagnostic test on the Wheel speed sensors and ABS sensors? I replaced all of mine after finding out that that is what the issue was and now she runs beautifully.
Picodroid
Dec 7, 2021 11:08 AM
d.sull
Jun 18, 2014 07:31 PM
knight_yyz
Aug 21, 2013 07:36 PM
max95q
Feb 13, 2006 09:54 AM
