OBD Won't Connect?
OBD Won't Connect?
'05 Maxima, daughter's car.
Using a little cheap bluetooth OBD reader from Amazon. It used to work on the Maxima and still works on my Rogue, but it won't connect to the Maxima now.
The car had blinking Check Engine while she was driving and then died. I had it towed back home but now it won't connect to the diagnostics. Battery is new, starter cranks strong, but won't start. I recently replaced all plugs and coils, so they should not be an issue - plus the car will start (badly) with just two or three cylinders firing so if it's spark problems, it's all of them I think.
Any ideas?
Any ideas?
I did plugs and coils about two weeks ago, and it ran for a week before dying. It has a blown ignition fuse and replacing it blows the fuse immediately.
As far as what I disconnected to remove the intake plenum, basically everything attached. Vacuum lines, sensor connections, etc.
Unfortunately I had to take it to a mechanic and pay several hundred dollars to figure it out. Floating ground was blowing coils open or short and was the problem from the very beginning. Shorted one of the coils I replaced which blew the ignition fuse - which was why I couldn't connect the OBD to the ECU. The mechanic blew three coils in the course of his trouble shooting, in fact. It's running like a champ now.
smai555
Nov 21, 2011 12:02 PM
Pilot8680
Sep 7, 2007 09:48 AM
Orion
Sep 17, 2003 07:18 PM
