2008 Max Knock
2008 Max Knock
Bought this 08 new and has 87,000 miles. The car is 95% driven by the wife. Never had problem with this car and only maintenance performed has been brakes, oil changes, transmission and radiator service. I really love this car compared to my 03 Max that I also bought new and has 147,000 miles plus have spent some 10K towards its upkeep. Plan on keeping it another couple years. Back to the 08, it developed an engine knock I heard when wife was parking in our garage. I couldn't believe It so took it to a mechanic I know and he told me he found mains 3 and 4 to be worn and is going to replace all the rod and main bearings. Some of the cap bolts were broke and some broke when pulling the caps off. Good thing is its fixable. I've read, in the forums, that the number 1 main on the V6 engines can go bad cause knocking. Not this time. Really was a big letdown.
Fixed....still wondering how this engine suffered so much abuse. I do know that where I had my oil changes performed they overfilled by almost a quart and before I noticed by looking at the oil stick I had driven this car like that for a couple months.This car's oil level is booked at 4 1/2 quarts. I pulled out at least 3/4's of a quart to get the level back down to where it was readable on the dip stick. Not sure, but I don't think having too much oil in the sump did this engine any good.
I always heard that too much oil can damage seals, not likely to damage a bearing. That's an unqualified answer, I don't do engine work like this, so I don't know for certain. Just sounds like it was likely something else and not 2 months overfull...
I don't believe it was that overfilled because I only drew out about 1 quart to get it to level. I didn't know there was a splash pan below the camshaft. Anyway, got it back but the mech told me to bring it back after 500 miles so he can go back to verify the torque values still hold, a one day job. You recon they do that as part of a factory assembly after a run in? I never did that ck while working on diesels in the AF.
pbn85
Fluids and Lubricants
Jun 3, 2007 09:27 AM
Smeagol
Nov 6, 2003 08:39 PM
maximanian
Feb 11, 2002 08:34 PM
