In dire need of assistance
Old Dec 12, 2019 | 07:01 PM
Maxima_08's Avatar
Code P0300 cant figure out why
I have an 08 maxima an my check engine light is flashing, so far I changed the spark plugs and coil packs after doing so my raidator cracked so I had to get a new also. My car also starts shaking around 1500 rpm and 40 mph but if I go over 2000 rpm and over 50 it stops shaking but the check engine lights keeps flashing
Old Dec 12, 2019 | 08:23 PM
User1's Avatar
Post your codes. Balance your wheels. Replace your axles.
Old Dec 13, 2019 | 05:25 AM
Maxima_08's Avatar
My tires are new an balanced and the code is P0300 and I lose power and car shakes around 40 to 50 and 1500 rpm and check engine light starts to flash
Old Dec 13, 2019 | 09:22 AM
A CEL that is flashing means that one or more of your fuel injectors is malfunctioning and too much fuel is being dumped. Per the FSM, the vehicle should not be driven when this happens.
0300 is a generic code for misfire. You've replaced the spark plugs (hopefully with NGK's), replaced the coilpacks (hopefully with OEM), all that is left is the injectors.
Clear the code and check again. With any luck, you'll get a specific cylinder code like 0301, 0302 etc
dshinn
Sep 26, 2015 08:07 PM
ruiqiangli
Sep 4, 2013 06:55 AM
bds
May 9, 2006 01:50 PM
LarryH
Nov 11, 2004 10:39 PM
Seba2K2
Dec 7, 2003 04:00 AM
