2005 Nissan Maxima - slip light during deceleration
Old Aug 14, 2020 | 03:36 PM
Carl Travis's Avatar
Hey folks, I have an issue that has just recently come up with my Maxima whereas upon deceleration my slip light engages and I hear my ABS also engage. It started out very randomly during cornering and now it engages almost anytime I drive. It does it at low speeds and also at high speeds. I've never had a check engine light come on and I can't figure out why this is happening. I have had my ABS sensors replaced and that has not fixed the problem. I have seen on other threads for years that this year range is extremely problematic with the ABS slip light and that there are big problems with the controllers for this year model. Can anybody invite me on what might be happening here?
Old Sep 16, 2020 | 12:56 AM
6thgen6spdbw9's Avatar
You'll need to check,clean or replace a rear wheel speed sensor, its a bad drainage problem found on most 6th gens causing corrosion to build up and interfere with the sensor reading...hth
Old Sep 16, 2020 | 04:31 PM
User1's Avatar
Pull your codes.
Old Sep 18, 2020 | 05:09 PM
Mikesima's Avatar
Dude. Get this looked at immediately! If all the lights come on and stay on, there's a good chance the abs actuator is blown. Don't drive like this.
This happened to my 2004 way back in the day and it's big $$$. It got to the point where I couldnt drive without turning off the traction controI (felt like the traction control was always turning on, couldn't drive more than 5kph). Never bothered to fix it and its one of the main reasons I dumped the car.
Juuuuist out of warranty, pissed me right off.
jtowarn
Feb 20, 2011 06:53 AM
trenddiggy
Sep 28, 2003 01:58 AM
sinewave
Apr 21, 2001 10:17 PM
