What is causing the car to jerk?
Old Oct 25, 2020 | 04:53 PM
Quardarius Raglin's Avatar
I have an 08 Maxima at first the alternator went bad and the guy that was fixing it had two projects ahead of me and the last one a truck fell on his arm that being said the car may have sat for a month and a few weeks. Had the alternator replaced now the car jerks not off take off but it’ll catch on. Had the codes read and an engine misfire and two emission leaks were detected. I’ve had all 6 spark plugs and bumpers replaced also the valve cover. Now the car is losing power. Any Suggestions???
Old Dec 10, 2020 | 09:24 AM
NismoMaximaA32's Avatar
Try replacing the camshaft and crankshaft sensors. They always go bad on these cars.
Old Dec 10, 2020 | 12:23 PM
Yrod6's Avatar
Originally Posted by nismomaximaa32
try replacing the camshaft and crankshaft sensors. They always go bad on these cars.
+10
Old Dec 12, 2020 | 12:24 AM
6thgen6spdbw9's Avatar
So true..
you said you changed 6 plugs did you reuse the old coil packs?
I hope you didn't use a shop and that your a diyer
Old Dec 15, 2020 | 05:45 AM
NC00DEK's Avatar
Seems like the car should throw the specific code for the camshaft position sensor. When mine went bad, it did. But it also had different symptoms, like stalling when coming to a stop.
before you replace them both, you can remove the sensor and see if it just needs to cleaned. Mine had a layer of grime on it and dirt or burnt oil in the holes on the sensor. I probably could have cleaned it so it could get a better reading. If you do happen to have this replaced make sure you buy the exact OEM part that the car came with and not another brand.
What are the exact codes it's throwing?
If the misfires are coming from the two cylinders controlled by the same coil pack then that one might seem pretty obvious.
mrDXB
Mar 9, 2020 11:12 AM
haus_A34
Jun 4, 2014 06:59 PM
BigSlimDog
Jan 16, 2013 12:44 AM
LithiuMax
Jun 3, 2004 09:39 AM
meccanoble
Aug 13, 2003 07:05 PM
